how to change a 95 v6 accord radiator
Old Apr 21, 2003 | 05:33 PM
dchi_t's Avatar
Default how to change a 95 v6 accord radiator
does anyone know exactly the steps on how to replacea 95 v6 accord radiator?
Old Apr 23, 2003 | 08:45 PM
Canonm7's Avatar
Default Re: how to change a 95 v6 accord radiator (dchi_t)
RTM - Read the manual
Old Apr 23, 2003 | 08:51 PM
iam7head's Avatar
Default Re: how to change a 95 v6 accord radiator (Canonm7)
squeeze off the upper and lower hose(anti-freeze spillage), remove the fans and harnness, take off the upper radiator mount(two bolts size 10-12??)
Old Apr 23, 2003 | 08:53 PM
iam7head's Avatar
Default Re: how to change a 95 v6 accord radiator (iam7head)
Pretty much all the same, pulled my dad's old one out of his nissan the same way, oh yeah let the green poo poo go first lol
Old Apr 23, 2003 | 09:03 PM
00WhiteEKy's Avatar
i didn't need to take the fans off. just take the hoses off, and the electrical plugs off, and unbolt it, and the pull the thing out, if your doing it becasue its broken, just pull the freaken thing out.
Old Apr 23, 2003 | 09:30 PM
iam7head's Avatar
Default Re: how to change a 95 v6 accord radiator (92hatchy)
Oh, it was on my dad's old skool nissan that's why.
Old Apr 25, 2003 | 05:48 PM
dchi_t's Avatar
i heard somewhere say something about transmission cooler connected w/ the radiator? is there such a thing?
Old Apr 26, 2003 | 12:53 PM
YeuEmMaiMai's Avatar
no cooler for the radiator
Old Apr 26, 2003 | 12:58 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dchi_t &raquo;</TD></TR><TR><TD CLASS="quote">i heard somewhere say something about transmission cooler connected w/ the radiator? is there such a thing?</TD></TR></TABLE>
Yes, two hoses.
Old Apr 26, 2003 | 03:56 PM
00WhiteEKy's Avatar
Default Re: how to change a 95 v6 accord radiator (Chiovnidca)
if it is an automatic, it will have 2 oil lines to cool the tranny. I have a automatic radioter in my manual car, just left the lines open. No biggie.
Old Apr 26, 2003 | 05:34 PM
CaMiKaZi's Avatar
Dont you have to flush the radiator
so u can clean the air that is inside?
Old May 7, 2003 | 09:35 AM
dchi_t's Avatar
do you know how to flush the coolant system? and i do have an automatic, so there are 2 hoses that connect to the tranny cooler?
Old May 7, 2003 | 11:42 AM
usually they will disconnect one rad hose hook it to a machine in between the rad and hose and power flush it
or if you want to do it your self
1. open rad cap (car must be cold)
2. drain coolant and tighten bolt
3. add distilled water and power flush (prestone works nicely)
4. after following flush instructions, drain flush solution from system
5. open drain plug on bottom of block to drain out ALL reminants of coolant flush
6. tighten drain plug and rad and block
7. fill with distilled water run for a few mins to get any remaining crap out
8. drain via rad plug and engine block plug
9. retighten all drin plugs
10 fill with recommended mix of coolant / water (usually 60/40)
TOO MUCH TORQUE
Jan 25, 2012 10:09 PM
horaceoli72
22
Nov 7, 2011 06:39 PM
Rawr123
May 21, 2006 12:55 AM
Infinity5
Jan 16, 2005 10:17 AM
