3rd gen help need help on taking the main fog lights out??
Old Apr 21, 2003 | 04:13 PM
lude019's Avatar
Default 3rd gen help need help on taking the main fog lights out??
Just as the post says. Stupied question really, but I cant figure out how to take them out. Need to change the bulbs in them. Any help would be cool thanks
Old Apr 21, 2003 | 04:18 PM
chrisb's Avatar
Default Re: 3rd gen help need help on taking the main fog lights out?? (lude019)
On the 90-91 model here is what you do:
1) Remove the single screw that holds the driving/turn signal lights in place.
2) You will then see two fog light screws. Loosen those completely.
3) Then there are two or maybe 3 slits in the bumper on the other side of the fog light. I think it is three slits.
4) Stick your screw driver through the top slit and loosen the screw. You have to work a bit to find the screw with the end of the screw driver.
5) Do the same with the bottom screw. The slit in the middle aims the foglight. Don't mess with it.
6) The fog light should come out. Change the bulb and make sure not to touch the new bulb with your fingers.
7) Reassemble.
Old Apr 21, 2003 | 04:21 PM
lude019's Avatar
Thanks alot man .
douglaslovin
Apr 6, 2009 04:50 PM
NSX4evr2006
Apr 17, 2006 04:52 PM
kidbrown7
Jul 12, 2005 06:44 AM
XplodeTeg
Aug 8, 2004 02:25 AM
