195/60/14 Azenis - what tire pressure for autoX/street? (searched)
After searching, I've only found recommended pressures for 205/50/15 tires. Nothing for 14's. This is on steelies.
Thanks
Thanks
I run 43f/31r in my 195/60R14 Azenis. Best thing to do though is experiment, and see what works for your car and your suspension setup. I'm running ~260f/325r, with Koni yellows (full stiff up front, half stiff in rear) Turn-in is crisp, rotation is very easy and predictable.
Also with Koni yellows at 1/2 stiff front 3/4 stiff rear, 300f/350r for springs, I have been running 37f/34r ish. Rotated a little too much with the front shocks at 1/3 stiff. Will be running an AX school event on the 27th, plan on using it to play with settings, pressures, and driver
Thanks. I'm experimenting like 89STS recommends all the time, and it's paying off. The thing is that I have crappy AGX shocks and H&R race springs, limiting the accuracy of the outcome. Your answers are more than I could've asked for, but if we could add to it, that would be great. There isn't too much info on 14" Azenis or any 14" semi/race race tires.
Thanks
Thanks
schumi
Jan 20, 2006 04:58 PM
Maddhatcher
Apr 25, 2003 04:40 PM
VTECAcuraGSR
21
Apr 16, 2003 02:20 PM
91SiKen
Sep 24, 2002 05:12 PM
