valve adjustments, an easy way?
Old Apr 21, 2003 | 03:46 PM
tek_civic's Avatar
Default valve adjustments, an easy way?
i have a haynes and a chiltons repair manual and the way they detail checking and adjusting valve clearences is sorta long, i was just wondering if there was an easier way to do it since i just intalled a new camshaft and it needs adjusting. can i turn the crank without taking off my ps, alt, ac pully? or do i have to take it all off? tnx
Old Apr 21, 2003 | 03:48 PM
Dancing is Forbidden's Avatar
Default Re: valve adjustments, an easy way? (tek_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tek_civic &raquo;</TD></TR><TR><TD CLASS="quote">i have a haynes and a chiltons repair manual and the way they detail checking and adjusting valve clearences is sorta long, i was just wondering if there was an easier way to do it since i just intalled a new camshaft and it needs adjusting. can i turn the crank without taking off my ps, alt, ac pully? or do i have to take it all off? tnx </TD></TR></TABLE>You should be able to turn the crank by hand.
Old Apr 21, 2003 | 03:57 PM
tek_civic's Avatar
Default Re: valve adjustments, an easy way? (EF9_SiR)
so you think i can turn it without taking off the accessory pully?
Old Apr 21, 2003 | 04:03 PM
t0p_sh0tta's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tek_civic &raquo;</TD></TR><TR><TD CLASS="quote">so you think i can turn it without taking off the accessory pully?</TD></TR></TABLE>
Remove your spark plugs, and it turns easily.
Old Apr 21, 2003 | 04:11 PM
tek_civic's Avatar
Default Re: valve adjustments, an easy way? (t0p_sh0tta)
ok cool. now i just have to wait for the engine to cool down. any other tips on adjust/checking before i get started?
tnx
Old Apr 21, 2003 | 04:31 PM
tek_civic's Avatar
anyone have any tips??
Old Apr 21, 2003 | 04:59 PM
Lord Helmet's Avatar
a helms manual is a good idea
vietdragontekx
Apr 21, 2006 10:40 PM
Beave0101
Jun 21, 2003 11:39 PM
Rtzx9r
Apr 7, 2003 11:54 PM
97ex+zex
Feb 4, 2003 01:45 PM
maxxdout
Jan 23, 2002 05:10 PM
