koni installation$$$???
Old Apr 21, 2003 | 03:36 PM
DR.DRum
Guest
Posts: n/a
Default koni installation$$$???
is 120$$$$ a good deal??? for someone installing some koni yellows on a 00lude
Old Apr 21, 2003 | 03:54 PM
Krypto's Avatar
Default Re: koni installation$$$??? (DR.DRum)
do it yourself
Old Apr 21, 2003 | 03:56 PM
VTECorona's Avatar
Default Re: koni installation$$$??? (Krypto)
DIY man, I did my first suspension on my own car and had no problems, just make sure you have the necessary tools and a helms\haynes manual before you start. If thats not an option then yeah, that is a good price. I have friends that have paid from 200-350 for a spring/shock and coilover/shock install.
Old Apr 21, 2003 | 04:28 PM
del_parker's Avatar
i'll do it for $50
Old Apr 21, 2003 | 04:41 PM
sslude's Avatar
Default Re: koni installation$$$??? (del_parker)
seems alittle pricey. jsut get some friend that are alittle knowledgeable and get them to help you ont he install. it should be too hard.
Old Apr 21, 2003 | 04:52 PM
ludin92's Avatar
Default Re: koni installation$$$??? (sslude)
the cheapest shops here do it is $140 which is still a lot more than i'd pay to have it done. my new shocks should be here in a couple days and decided to just do it myself. do it on a weekend day and take your time.
Old Apr 21, 2003 | 05:03 PM
DR.DRum
Guest
Posts: n/a
Default Re: koni installation$$$??? (ludin92)
dam it is pricey, but anyone is socal know where i can get it done cheaper??
cuz i cant do it myslef, and dont have local hookups just moved to socal not too long ago.
Old Apr 21, 2003 | 05:18 PM
One Slow Lude's Avatar
i was quoted at 150 for mine to be put in....i had some friends do it that had spring compressors, lift, yada yada..... if you dont know what your doing i would suggest making friends with someone that does and do it over one weekend.....and let your bolts sit in penetrating oil over night it helps alot.....i have seen someone break some bolt head doing it themselves without trying to loosen the bolts first...big mess
Tuney's Avatar
Default Re: koni installation$$$??? (POSlude97)
its easy, don't be afraid to get dirty.
Old Apr 21, 2003 | 05:23 PM
Tee Jay's Avatar
Default Re: koni installation$$$??? (Tuney)
I recommend WD-40 or something of that sort
Old Apr 21, 2003 | 06:48 PM
DR.DRum
Guest
Posts: n/a
Default Re: koni installation$$$??? (Prelude_Si)
dam anyone in socal for cheeper?
Old Apr 21, 2003 | 06:56 PM
VTECorona's Avatar
Its a fun little project man, get your hands dirty. You will be happy after you finish knowing exactly what happened during the install. I don't trust hardly any mechanics on my car, pretty much only honda mechanics and even them I'm a little skeptical about sometimes.
Old Apr 21, 2003 | 08:42 PM
Prelude Vtec 23's Avatar
Default Re: koni installation$$$??? (97RedTegGSR)
Yeah....do it yourself, learn and get some experience. If you have any trouble ask us and we can help you
Old Apr 22, 2003 | 01:37 AM
GSRrR's Avatar
http://www.bseries.net/html/garage/spring.php
if you really can't/do not want to DIY. where in socal are you?
blaze the chemi
Suspension & Brakes
Dec 14, 2008 07:46 PM
Rahxephon
Suspension & Brakes
10
Mar 2, 2007 05:40 AM
lude98SH
Sep 25, 2006 10:20 PM
tylerdurden
Aug 22, 2002 04:45 PM
reVVin
Mar 19, 2002 05:51 PM
