is will b16a header fit on b18a head
Old Apr 21, 2003 | 03:36 PM
untitled's Avatar
Default is will b16a header fit on b18a head
as above.
Old Apr 21, 2003 | 03:39 PM
VTECorona's Avatar
Default Re: is will b16a header fit on b18a head (88crx91integra)
I'm pretty sure yes because if I'm not mistaken the type-r head is the same as a b16 head. But I'm not sure about b18a since there's no vtec. just my .02
Old Apr 21, 2003 | 03:54 PM
Padawan's Avatar
Darth ModerVader
It will bolt to the head just fine. Only problem might be clearing the oil pan, since the B16A has a shorter deck height.
Old Apr 21, 2003 | 03:59 PM
VTECorona's Avatar
Default Re: is will b16a header fit on b18a head (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">It will bolt to the head just fine. Only problem might be clearing the oil pan, since the B16A has a shorter deck height.</TD></TR></TABLE>
I was just thinking that, since the displacement is a fifth more, the block is going to be slightly higher which may not allow the header to clear the block.
Old Apr 21, 2003 | 04:32 PM
untitled's Avatar
Default Re: is will b16a header fit on b18a head (97RedTegGSR)
Old Apr 21, 2003 | 04:39 PM
psi420's Avatar
It will be just fine!
Your exhaust may need modifying to line up, but other than that, everything will fit.
9honda5civic
Sep 10, 2012 07:51 AM
91DApwr
Aug 26, 2005 04:56 PM
untitled
Apr 21, 2003 03:26 PM
mr.beeks
Apr 16, 2003 09:47 PM
90crxsir
Nov 7, 2001 06:23 PM
