whats the difference between buying a racing cat and clearing my stock cat?
is there a difference between clearing my stock cat and buying a racing cat...
which one would be better? thanks
The racing cat prolly has a smoother internal surface for air to flow through.
Taking a hammer to your stock cat to **** it all up would be just cheaper and maybe work just as well.
The racing cat prolly has a larger diameter piping too.
"Clearing your stock cat" is illegal first of all and secondly if you find the right cat then I would assume that a "racing cat" would be better. I hear good things about carsound cats but if you break all that ceramic **** out of your stock cat it should be about the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arsenaldragster »</TD></TR><TR><TD CLASS="quote">Buy a hi-flo cat or straight pipe. keep your stock cat for smog time!!
you can prob find a test pipe for like 50 bucks
and to all the tree huggers, ride a bike and stop driving your car
</TD></TR></TABLE>you can prob find a test pipe for like 50 bucks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tuney »</TD></TR><TR><TD CLASS="quote">
the diff between hi-flo and a test pipe is about 1hp. why risk the fines for just 1 hp?
</TD></TR></TABLE>the diff between hi-flo and a test pipe is about 1hp. why risk the fines for just 1 hp?
The difference is the racing cat continues to clean the engine emissions like the stock one does, but allows a higher flow. Gutting the stock one obviously does nothing to help clean the emissions.
