zdyne 1 wire
im going to order the zdyne 1 wire conversion. whats the 1 wire i have to hook up? word is this is the **** for my z6 obd0. its like a pr3 for a z6! any info on the product appreciated. wiring doesn't scare me... so far.
Its goes to the VTEC solenoid.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">The B16A One Wire Conversion is the fastest and easy way to run your hybrid. No RPM switch boxes or harness swaps required - Run just a single wire for your engine swap!
Unlike all other "B16 retunes" the ZDYNE B16 One Wire Conversion comes complete with VTEC solenoid control built into the ECU. Full VTEC operation with sensitivity for water temperature and throttle position. Fuel and ignition curves are doubled and recurved for correct operation of VTEC and non-VTEC modes. Road tested and now dyno tested to within 1 peak HP of B16A JDM ECU!
Perfect for B16A VTEC engine swaps or D16Z6* / D16Y8** VTEC head swaps
*The 88-91 Si/HF distributor is required. **88-91 Si/HF distributor bolts right on! </TD></TR></TABLE>
http://www.zdyne.com/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlickCRX »</TD></TR><TR><TD CLASS="quote">im going to order the zdyne 1 wire conversion. whats the 1 wire i have to hook up? word is this is the **** for my z6 obd0. its like a pr3 for a z6! any info on the product appreciated. wiring doesn't scare me... so far.
I've got one for my mini-me. It's pretty good and expensive: $330. I suggest some sort of vtec controller (just to move the engagement point lower 45-4600) as there is a drop between the primary/secondary cam lobes.
</TD></TR></TABLE>I've got one for my mini-me. It's pretty good and expensive: $330. I suggest some sort of vtec controller (just to move the engagement point lower 45-4600) as there is a drop between the primary/secondary cam lobes.
good luck
i placed a call over a week ago and have sent 2 emails so far, and received no response, i ended up finding one used,
i might sell it though if ur intrested, i will let u know this weekend.
i just called the number 1-818-888-5350 and a rep picked up and spoke to me. we actually ended up having a 20 min conversation about ecus for a z6 and about turbo later. yeah, the first time i tried to fax my order form it won't go thru cause they keep their fax machine off cause of junk mail, and you have to call so they're expecting it. also the number on the site is different. (818-340-1770 if you're interested.) the rep said i will get it buy friday and i ordered today. he was saying to get the z6 tune cause it runs better, like a p28 obd0. apparently some of the guys that work there tested it for a while, used a b16 tune, and preferred the z6 for driveability and performance. and if, scratch that, WHEN i go turbo i can send the ecu back in, pay the difference for the gold tune, and control everything. i am interested in your ecu though. i would like to try it anyway, or if not my friend really needs it. his feel's chip is ******* him up. let me know about the ecu.
lsvtecSIrex
Jun 14, 2006 03:13 PM
