wire hareness?
What im looking to do is make a huge wire harness so i can splice in all my speaker wires into one large harness w/ a male or female end...then take the oppisite end and wire it all up to my amp so i can pull my amps out whenever i want and only disconnect one large harness instead of like 20 other ones...anyone know where i can find a universal wiring harness w/ 8-12 pins w/ male and females ends that will accept 12 aug wire? any help is greatly apprciated!
I was looking into the molex connectors, but they are soo dam small only accept 18 aug. Also i was talking to my freinds dad who works ofr xerox and said i would burn out the pins and such not....i tried looking today in the junkyard for some cars wire harnesses but they all use tiny gauges such as 16 aug...omg if no one has made this people should!!! I want to make life easy..and not have to undo like 12 different banna plugs...grrr
You could look into barrier strips, but you'd still have a mess of wires and screws to play with, so nevermind.
If you figure something out, be sure to post it
