Quick Q: Carsound cat owners help
Old Apr 21, 2003 | 02:03 PM
JunIntegra's Avatar
Default Quick Q: Carsound cat owners help
just got it in today for my teg and dc jdm.
1.what gasket will i need for the header-cat?alls it is is a flare with the bolt bracket
2. for the header-bpipe would be the 2.5 gasket,right?
3.and do i need longer bolts for the header-cat section>?
this must go on tomorrow
Old Apr 21, 2003 | 02:40 PM
Aaron M's Avatar
Default Re: Quick Q: Carsound cat owners help (JunIntegra)
You lucky lucky guy. I just did my header and cat install a few weeks ago, so I can give you all the help you need. I hope this helps. You can PM me if you need more help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunIntegra &raquo;</TD></TR><TR><TD CLASS="quote">
1.what gasket will i need for the header-cat? Honda S2000 donut gasket(goto your local honda dealership and ask for part number 18229-PCX-003, if they dont have it you can also try your acura dealership and ask for the v6 legend donut gasket
2. for the header-bpipe would be the 2.5 gasket,right? do you mean cat-bpipe connection? if so just head down your your local pep boys and in the exhaust section you should find a round 3 bolt gasket made by "Mr. Gasket" get the 2.5" one. It's a 2 pack for about $4
3.and do i need longer bolts for the header-cat section? yes you do. you need (2) 4" bolts, (2) washers(1.5" i think, or as round as the spring), (2) 1/4" washers for the header side, and (4) nuts(2 on each bolt and lock them together) </TD></TR></TABLE>
EDIT: Almost forgot to tell you...
You will also need new bolts/nuts for the cat-bpipe connection. I used (3) 1.5" bolts and double nutted them, along with washers on both sides of the connection. Using 2" bolts wouldn't hurt either.
Modified by SilverB18C1 at 5:18 PM 4/21/2003
Old Apr 21, 2003 | 04:13 PM
P1mpSlap's Avatar
bump, good info!
lowtegsr
Jun 14, 2008 11:56 AM
xunkn0vvnx
Sep 11, 2005 06:52 PM
voofee
Nov 15, 2003 07:30 PM
SpeedRacer00-667
Jul 25, 2003 08:48 PM
jdmspoonitr
Nov 25, 2002 04:46 PM
