Is 00 civic Si radiator a perfect match in a 92-95 Si?
Old Apr 21, 2003 | 01:52 PM
Si_Allen's Avatar
Default Is 00 civic Si radiator a perfect match in a 92-95 Si?
Like the topic says, just wondering if the radiator from 00 si will fit into my 92 si hatch with stock d16z6? Thanks. Let me know
Old Apr 21, 2003 | 01:55 PM
Extreme's Avatar
Default Re: Is 00 civic Si radiator a perfect match in a 92-95 Si? (Si_Allen)
No exactly, the Si radiator has wider B series neck. You'll have to stretch your hoses to fit. Perfect if you have a B series swap.
Old Apr 21, 2003 | 02:01 PM
rainmanEK's Avatar
big strong guy
Default Re: Is 00 civic Si radiator a perfect match in a 92-95 Si? (Extreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Extreme &raquo;</TD></TR><TR><TD CLASS="quote">No exactly, the Si radiator has wider B series neck. You'll have to stretch your hoses to fit. Perfect if you have a B series swap.</TD></TR></TABLE>
Why perfect?
They are Single Core Just like SOHC civics!
Eric
Old Apr 21, 2003 | 02:21 PM
Extreme's Avatar
Default Re: Is 00 civic Si radiator a perfect match in a 92-95 Si? (rainmanEK)
Probably not for anyone pushing *BIG* horsepower.
But for stock to mild setup it should be, and Honda seems to agree
Old Apr 21, 2003 | 02:37 PM
Si_Allen's Avatar
So all the electrical and mounting hardware will be the same and I will only have to slightly strech the hoses? Will my engine show any check engine lights?
Old Apr 21, 2003 | 02:43 PM
VTcivic
Guest
Posts: n/a
it shouldnt, the radiator should mount right in, with the exception of longer hoses, and maybe drill a new hole for the mounts, but other than that, it should be clear sailing.
Old Apr 21, 2003 | 02:44 PM
Si_Allen's Avatar
Default Re: Is 00 civic Si radiator a perfect match in a 92-95 Si? (VTcivic)
thanks for the info.
zerovandez
13
Jun 28, 2007 08:36 PM
mikeycivic
Jan 3, 2007 05:26 PM
civichatch67
Oct 21, 2005 06:37 AM
SiR831
Feb 19, 2005 01:11 PM
wdskuk
Jan 24, 2004 07:56 AM
