camber kits?
Ok guys i have a few questions. i dropped my car about 2 inches all around and know i need camber kits for the front. I don't want to spend all kinds and was wondering whick camber kits to get. Second do i need camber kits for back? I don't think i do but some mechanic told me i did. Thanks.
I have a 96 LS and recently dropped my teg on Skunk2 coilovers. I got the Specialty Products camber kit for the front, and just did the 'washers' camber kit in the back. I believe I used 2 washers for each side. Right now the Group Buy website has a buy going on for the Specialty Products kit.
http://www.groupbuycenter.com/buy.aspx?id=9535
Hope this helps.
Hope this helps.
i have ingalls, but some people say they have had problems with them. i havent. i would go with either ingalls or skunk2s. i hear good things about those also. about the back, i dont have a kit for the back, but ill prolly buy a set when i happen to have some extra cash lying around. its not as big a deal in the back as it is in the front.
go engalls i have heard nothing but good about them! also the back is just longer bolts with 2 washers on each its a rip off to order just add two of the same size washers to each side. that should do you just fine. i lowered my car with eibach sportlines and i havent even purchased a camber kit for mine! i dont need one i havent had any camber issues no tire wear and i took it to the local alignment shop and they said everything is online and a kit wont be necessary maybe i just lucked out but before you drop the loot i would say take it to the shop and when you get it aligned have them look at it
hollaback, aren't you from NM? Anyways, I would recommend the skunk2 front camber kit and the bolt/washer trick for the back.
TailZ
Honda Civic (2001 - 2005)
12
Jun 16, 2010 07:21 PM
