mini me!!!!!!!!!!!!!
i just finished getting the jet off my block.
my vtec is working.
is it normaal that when i put the vtec wire too bat + something begins to rattle in the head??
is it the thirth cam lobe kicking in??
my car is a 89 crx si
i bought it with a d15b7 engine in it.
it was slightly modified and i think it has larger injectors.
a month ago i brought them to napa for cleaning and the report was a flow rate of 84 ml.
what size of injectors do i have curently??
what ngk spark plug heat range is good for the mini me??
i have a z6 head with y5 gasket (1mm)
what compresion ratio am i running??
can someone advice me some basic tuning of a b7/z6 mini me??
thanks in advance
*-WJT-CRX-*
my vtec is working.
thanks in advance
*-WJT-CRX-*
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WJT CRX »</TD></TR><TR><TD CLASS="quote">
is it the thirth cam lobe kicking in?? </TD></TR></TABLE>
Yeah.. Doesn't sound like that's too hot of an idea.. but it does seem funny.
I have a Y8 head so I used a Y8 plug but 1 heat range cooler... I think you could easily do the same for a Z6 head. Any parts store will be able to tell you what the plug # is.
Compression calculator
Yup.. Stock everything, adjust timing till you get rid of any "pinging" and then to the dyno. Don't bother with cam adjustments or fuel/air until you are able to get on a dyno and see what you are doing, you may end up doing more harm than good.
advice take the vtec wire off your battery and use a fields vtec controller.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyle h. »</TD></TR><TR><TD CLASS="quote">
advice take the vtec wire off your battery and use a fields vtec controller. </TD></TR></TABLE>
or a vafc
or a vafc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WJT CRX »</TD></TR><TR><TD CLASS="quote">i hooked the vtec to a autometer shift light</TD></TR></TABLE>
Then why were you talking about hooking it to the positive battery terminal?
