Which axles and midshaft, B16A into 90HB
Old Apr 21, 2003 | 10:27 AM
ITR632's Avatar
Default Which axles and midshaft, B16A into 90HB
not sure
Old Apr 21, 2003 | 10:30 AM
Malgerus's Avatar
Default Re: Which axles and midshaft, B16A into 90HB (ITR632)
DO a search...
but here: use 90-93 Integra axles and Intermediate shaft, with the dust shields removed from the hubs, and make sure you remove the rings from the axles.
Old Apr 21, 2003 | 11:59 AM
doggunracing's Avatar
My friend's shop told him to get 90-93 Integra left and Del Sol right for his 91 CRX Si. I've always seen 90-93 Integra axles for both sides, but they said they were too long. Now the right side is rubbing/knocking, especially on right turns. Does he just need to swap it to a 90-93 axle? The stock hubs are okay, correct?
Old Apr 21, 2003 | 12:05 PM
Malgerus's Avatar
Default Re: (doggunracing)
Stock DX/Si hubs will work with Integra axles, and intermediate shaft. You can also use JDM Integra Intermediate shafts, such as the S1/J1's Intermediate shaft. The CRX Sir Y1/YS1 shafts are too long. I've never heard of anyone using Del Sol axles before. HTH.
Old Apr 21, 2003 | 12:09 PM
sparkz's Avatar
Default Re: (Mr. S)
it depends on which half shaft you use
94-01 Integra halfshaft then use 94-01 Driver side axles
as for passenger side axle, I always use 86-89 Integra passenger axle. 90-93 is too long
anotheredhatch
Aug 19, 2004 06:11 AM
lillex
Dec 4, 2003 04:17 AM
joey1320
Dec 17, 2002 04:20 PM
XANDER-666
Oct 7, 2002 12:04 PM
juicy.koreans.suck
10
Jan 10, 2002 10:47 AM
