How an Apex'i Vafc/Safc works?
Old Apr 21, 2003 | 08:29 AM
b18cya's Avatar
Default How an Apex'i Vafc/Safc works?
im using a vafc for fuel control on my turbo setup, & i was curious as to exactly how it works.
i know the afc taps onto the:
Throttle position sensor (TPS)
Manifold absolure pressure sensor (map)
vtec signal (vafc only)
i cant remember what other signal wires are used...
which signal does the afc modify so the ecu will add or remove fuel? & what other effects are caused.
I dont know if this is accurate, but what i understand so far is that the AFC modifies the MAP signal going to the ecu. when the ecu see's a lower map voltage, it removes fuel from the system...but i've also heard that in doing so, the ecu advanced ignition FAR...
chrisdata
Sep 18, 2004 04:37 PM
ArchAngel Sabastian
Jan 3, 2003 08:13 AM
R@mon
Oct 6, 2002 01:08 PM
VTECHGSR
Dec 13, 2001 04:30 PM
oryanh
Nov 14, 2001 10:15 AM
