torque, horsepower and compression
Old Apr 21, 2003 | 06:50 AM
mbsi's Avatar
Default torque, horsepower and compression
Does anyone on here actually know how all of this is calculated? What parts in a motor to replace to actally get some gains? Im just interested to know a bit further on how this stuff is calulated. For example if you replace a gsr head with a type r head on a B18C1 does this increase compression and why does it increase it? what parts make it increase? what's an example of higher compression, is 11:1 higher than 8:1? Thanx to anyone who can answer these for me.
Old Apr 21, 2003 | 07:46 AM
Lsos's Avatar
Default Re: torque, horsepower and compression (mbsi)
11:1 is higher than 8:1. In order to raise compression, you decrease the size of the combustion chamber relative to the displacement. You can do this by milling the head, installing domed pistons, welding material to the head, etc...
I don't think there's a simple formula to claculate how compression affects horsepower/ torque. A complex formula could probably be derived from extensive tests on various motors. I guess its accepted though, that a point increase in compression (from 8:1 to 9:1, for example) would net a 4% increase. I doubt this is accurate except maybe over a narrow range of compressions, and only with certain motors.
Horsepower = Torque (lb-ft) x RPM/ 5252
soon2bdropped
Oct 3, 2007 06:28 PM
Techna600f4i
Jun 19, 2006 11:49 PM
Propulsion
Nov 24, 2003 09:16 AM
CRneXt
Sep 27, 2003 07:56 AM
jeremy.
Sep 25, 2003 01:44 PM
