No Heat after AC control relocation.
Old Apr 21, 2003 | 05:24 AM
sparknblaze's Avatar
Default No Heat after AC control relocation.
Ok heres the ENTIRE story. On 3/21 my tranny went out and car coasted to a stop in the merge lane of a big street. 10min after I call the Tow truck some jackass slid into the back of me (yes the hazards were on). My car has been sitting in my driveway since. About a week ago I fixed the tranny problem which was a leaking hose. But while it was sitting I decided to do a little dash remodeling. I put the white face guages on and took out the AC controls and rewired them to go to the glove box and put two guage pods in the holes and the VAFC in the rectangular void. I cut and extended each wire PERFECTLY (one by one) but when I turn on the heat no heat comes out. Everything works but the heat. Any Idea what's up?
Old Apr 21, 2003 | 06:29 AM
YeuEmMaiMai's Avatar
Default Re: No Heat after AC control relocation. (sparknblaze)
looks like you forgot to plug in the control for the valve that lets warm coolant flow into the heatercore
Old Apr 21, 2003 | 06:44 AM
Default Re: No Heat after AC control relocation. (YeuEmMaiMai)
Do you mean the **** with the wire connected to it that selects the temperature? Or is there something else?
Old Apr 21, 2003 | 09:42 AM
there is steel rod goes through the firewall to a valve in a heater hose. You need to make sure that one is connected otherwise you will not be able to turn the heat on.
Jaxis
11
Jul 20, 2016 06:50 AM
rovafa2002
Dec 7, 2013 02:50 AM
greasemonky50
Feb 25, 2006 07:34 AM
fred
Oct 24, 2005 08:26 PM
