can you weld an AEM CAI?
Old Apr 21, 2003 | 04:32 AM
tomn_gsr's Avatar
Default can you weld an AEM CAI?
I just installed my CAI couple weeks a go. Yesterday,I found out that the bracket that mount too the chassy ripped a big hole on the pipe. Can I just weld them back instead of buying a new one?
Old Apr 21, 2003 | 04:58 AM
MrBite's Avatar
Default Re: can you weld an AEM CAI? (tomn_gsr)
It's aluminum, so you would need to do aluminum welding which is much more difficult and probably expensive.
Old Apr 21, 2003 | 06:01 AM
Blk98Teg's Avatar
Hey that happened to me to. I brought it back to the shop and starting bitching and they gave me a new one right there. I only had it for like a month to. But to answer your ques, yes it can be welded. But you need somebody who has a TIG welder.
Old Apr 21, 2003 | 06:20 AM
JeremyL's Avatar
Default Re: can you weld an AEM CAI? (Blk98Teg)
just rwap some good metal tape around it or do a JB weld
Old Apr 21, 2003 | 06:25 AM
VTEC-DA's Avatar
Default Re: can you weld an AEM CAI? (JeremyL)
I would get some sand paper and clean up the hole. Make is smooth to the touch. Then, get yourself some metal paper and wrap the **** out of it. You dont even need that paper anyway. May look ghetto, but it will work fine. Then spray paint the whole thing one color if you want, just to make it look a little better.
Old Apr 21, 2003 | 08:20 AM
OBDI JEDI's Avatar
Default Re: can you weld an AEM CAI? (VTEC-DA)
JB Weld !
Old Apr 21, 2003 | 09:49 AM
threatcon13's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tomn_gsr &raquo;</TD></TR><TR><TD CLASS="quote">I just installed my CAI couple weeks a go. Yesterday,I found out that the bracket that mount too the chassy ripped a big hole on the pipe. Can I just weld them back instead of buying a new one?</TD></TR></TABLE> that happened to me too it was on my injen cold air extension
Old Apr 21, 2003 | 09:56 AM
Acronym's Avatar
Get the tape that quacks!
Old Apr 21, 2003 | 09:57 AM
spoonfed95's Avatar
Default Re: can you weld an AEM CAI? (Threatcon13)
I say JB weld or Tig it.
Old Apr 21, 2003 | 09:58 AM
VTECorona's Avatar
Default Re: can you weld an AEM CAI? (Acronym)
It will probably lose the benefit of being mandrel bent but if you can't get it warrantied I would definatly weld it or patch it up somehow.
thrty8street
Dec 24, 2007 08:31 AM
iperez
Feb 4, 2005 11:07 AM
Matgallis
Feb 3, 2004 08:02 PM
majeed11
Aug 22, 2003 08:26 PM
RAB
Oct 18, 2002 07:10 AM
