Horrible Gas mileage? After an oil change
Old Apr 21, 2003 | 01:29 AM
ucb's Avatar
ucb
Default Horrible Gas mileage? After an oil change
Hi,
I recently picked up my 99 AV6 cpe. Its completely stock. Before my oil change i was getting about 27 mpg pure highway driving, and about 22 mixed highway/city. Then i got my oil changed about 2 weeks ago. From then on, my MPG dropped to about 15 mixed highway/city. What the hell did they do to my car, im guessin they used the wrong weight oil? Any other suggestions on ways to improve my MPG. The car has 55k on it. Do the infamous bad tranny's have anything to do with the MPG as well, because ive been getting a lot of rought downshits.
Old Apr 21, 2003 | 11:56 AM
jdowen2's Avatar
Default Re: Horrible Gas mileage? After an oil change (UCBGSR)
Check to see if any vacuum lines were disconnected in error or possibly broken. Maybe even vacuum lines that were disconnected and reconnected incorrectly.
Old Apr 21, 2003 | 12:58 PM
ucb's Avatar
ucb
ill check that, any other ideas?
Old Apr 21, 2003 | 04:04 PM
bill-71SS's Avatar
the wieght of the oil could be your problem. If you are using 5/20 and they put in like a 20/50, it will deffinatly drop you mpg.
Old Apr 21, 2003 | 07:51 PM
Razor's Avatar
Default Re: Horrible Gas mileage? After an oil change (bill-71SS)
did you fill up after the oil change? it could possibly be just some bad gas from that particular gas station.
Old Apr 22, 2003 | 12:49 AM
ucb's Avatar
ucb
Default Re: Horrible Gas mileage? After an oil change (Razor)
it was the same gas.
Old Apr 22, 2003 | 08:38 PM
ucb's Avatar
ucb
anyone else?
Old Apr 22, 2003 | 09:31 PM
SOHCMAN's Avatar
Maybe you have coincidently started dragging brakes?? Has to be some other system taking a ****...fouled your plugs? air fuel mix went to hell? checked your tire pressure
driving habits changed?? lol...
Hope you get it figgured out dude...
sohc
Old Apr 23, 2003 | 02:22 PM
RotaryBzzz's Avatar
Default Re: Horrible Gas mileage? After an oil change (SOHCMAN)
I'm assuming you've thrown no check lights?
Old Apr 23, 2003 | 02:27 PM
niedejb's Avatar
Default Re: Horrible Gas mileage? After an oil change (RotaryBzzz)
I bet they over filled the oil and your crank is having to slosh through the excess oil in the pan.
Have it changed again by a different shop and see if it goes away.
Old Apr 23, 2003 | 04:58 PM
ucb's Avatar
ucb
Default Re: Horrible Gas mileage? After an oil change (niedejb)
no cels, car seems to be running just fine, but the mpg is horrible
i think i may fork out the 35 bucks for a oil change from honda
Old Apr 23, 2003 | 09:31 PM
accordexchange's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UCBGSR &raquo;</TD></TR><TR><TD CLASS="quote">no cels, car seems to be running just fine, but the mpg is horrible
i think i may fork out the 35 bucks for a oil change from honda</TD></TR></TABLE>
who did your oil change then..?
Old Apr 24, 2003 | 12:57 AM
ucb's Avatar
ucb
Default Re: Horrible Gas mileage? After an oil change (accordexchange)
just a local shop. Second thought, perhaps I should start doing it myself.
Old Apr 24, 2003 | 01:31 AM
CaMiKaZi's Avatar
you might need to go back to them and make them do a check all over for free.
That is a lot of gas milage dropping
damn from 28 to 15 man u need to double your gas from now on
bigsnorlax
Apr 17, 2009 03:10 PM
00civiccali
Jul 21, 2008 09:15 PM
don24
Mar 7, 2006 08:34 PM
raylude
Mar 4, 2005 06:31 AM
mickey513
Sep 28, 2002 01:10 PM
