ITR Differential Question...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra_gsr98 »</TD></TR><TR><TD CLASS="quote">You will more than likely need an ITR/GSR counter shaft (i believe that is the one), pinion gear, and ring gear. </TD></TR></TABLE>
Can you confirm it?
Can you confirm it?
What is the model of the transmission and what final drive does it have in it?
If it does not have a factory 4.40 final drive like the GSR and ITR you will need the above specified parts, as the USDM ITR LSD is designed for use with a 4.40 FD ring gear.
If it does not have a factory 4.40 final drive like the GSR and ITR you will need the above specified parts, as the USDM ITR LSD is designed for use with a 4.40 FD ring gear.</TD></TR></TABLE>
the b16a transmission uses a 4.40 final and if memory serves correctly, the bolt
pattern is not the same as the b18c
sk8shorty012
Jun 3, 2008 12:07 PM
Black R
Dec 19, 2005 05:37 AM
