How do I remove the stock seatbelt????
If anyone can help me I would greatly appreciate it. I am trying to thread my stock seatbelt through my new SPG so that the lap belt can rest flush. I do not need to remove the part on the b-pillar, I need to remove the part near the bottom of the car next to the seat rail. I need to get that whole plastic thing attached to the belt to come loose so I can thread it through the side bolster and then bolt it back up. TIA
it would probably be easier to just undo the shoulder belt at the B-Pillar and just thread that through. assuming that the seat is already mounted in the car...
-tony
-tony
Peel back the plastic thing covering the belt at the pivot/mounting point. There is a bolt under there you can remove. Or you can pry off the little plastic circle to get to the bolt also.
if you do it, just be aware of all the little parts inside the seat belt compartment. there is little gears and pins, and you will need them. also it is a bit tricky when you take it off. you gotta extract most of the belt itself before you take it off of the chasis because it is grounded to the car. so if you do not have enough slack it will take you a while. good luck
gennaio
May 17, 2010 01:44 PM
