Clevite main and rod bearings?
Old Apr 20, 2003 | 08:37 PM
aeolus's Avatar
Default Clevite main and rod bearings?
Someone on here posted a pic a while back of the parts they were gonna use to build there prelude block with.I Remember they were gonna use Clevite bearings...Anyone else here ever use them??
Old Apr 21, 2003 | 05:52 PM
aeolus's Avatar
Default Re: Clevite main and rod bearings? (aeolus)
bump
Old Apr 30, 2003 | 04:40 PM
IN VTEC's Avatar
Lots of guys here use them. Commonly referred to as ACL bearings.
If you search archived topics created by Rocket, you should be able to find the composition and build info you're looking for.
As for bearing sizes and clearancing...they only produce two or three sizes, where only one is for standard sized for unground journals, and the other one or two sizes for journals that need to be turned down significantly (.010" and .025" oversized - 1/100" seems like a lot, so I might be a zero short).
The standard-sized bearings are usually sized somewhere in the middle of the bearing size chart and usually clearance just fine. If they don't, it's recommended to simply mix in an OEM Honda bearing to help it get into spec.
Old Apr 30, 2003 | 10:13 PM
aeolus's Avatar
Default Re: Clevite main and rod bearings? (IN VTEC)
Are you sure?I didnt know Federal Mogul and ACL were the same company.
Old Apr 30, 2003 | 10:16 PM
ludesleep's Avatar
im looking for bearings too..let me know what you guys find out
Old May 1, 2003 | 06:47 AM
IN VTEC's Avatar
Ok. Nevermind. Just kidding. They're not.
It's the assy lube that's included that's labeled Clevite 77. The bearing boxes are labeled as Duraglide 780 produced solely by ACL Bearing Company, a division of Automotive Components Ltd.
goat86
Apr 19, 2014 12:00 AM
SwagNationEK9
Nov 13, 2013 02:47 PM
MadVTI
Oct 4, 2009 05:47 PM
sir2k
Mar 5, 2003 11:33 PM
