Fuel line/hose question
Old Apr 20, 2003 | 08:28 PM
T3T495GSR's Avatar
Default Fuel line/hose question
well i just put my intank fuel pump in and i took out the inline one .. There is a problem though. You know how when you put an inline one in, you have to cut your fuel hose to get teh inline one in there and the connect those? well right now i have two hoses that arent connected and you cant get those hoses off cause apparantly they are crimped on? can you take those off? what is a way around it? my thought was to just get a thinner hose to go inside the stock hose that doesnt reach and connect it from one end to the other and use clamps to tighten and secure it???? or will this not work? any help is appreciated, thank you
Old Apr 20, 2003 | 09:19 PM
IN VTEC's Avatar
Default Re: Fuel line/hose question (T3T495GSR)
You're not gonna get a tight seal with that hose-in-a-hose trick.
You might be able to use a dual barbed-end fitting of the appropriate size with worm gear hose clamps.
Old Apr 22, 2003 | 05:43 AM
T3T495GSR's Avatar
Default Re: Fuel line/hose question (IN VTEC)
man did i get lucky, i called my import shop and drove an hour to get a brand new stock fuel line that goes from the fuel filter to the rail, with fittings attacthed and everything. 10 bucks
bump
Old Apr 22, 2003 | 06:20 AM
IN VTEC's Avatar
Si. That's mui bien.
carlos8
Dec 17, 2013 12:30 AM
Cowboy
Nov 26, 2003 01:45 PM
T3T495GSR
Apr 22, 2003 05:43 AM
T3T495GSR
Apr 22, 2003 05:42 AM
turbogsr13z
Mar 18, 2003 05:26 PM
