Cam gears slipping.............?
Old Jun 28, 2001 | 12:41 PM
Halo's Avatar
Default Cam gears slipping.............?
I know there are a few members i.e-non-vtec who had his tensioner, cam gear slip.....causing major damage to the head. How can one permently safeguard against this happening? Do I tighten the gears themselves or the crancase tensioner?
Old Jun 28, 2001 | 12:43 PM
Malice's Avatar
New User
Default Re: Cam gears slipping.............? (Halo)
use a lock-tite. but there is a very VERY slim chance of a cam gear slipping tho
[Modified by MaliceGSR, 9:43 PM 6/28/2001]
Old Jun 28, 2001 | 12:48 PM
Halo's Avatar
Default Re: Cam gears slipping.............? (MaliceGSR)
Ummmmmmmmmm.............. look at member FUKATYPR's post or member non-vtecs post
Old Jun 28, 2001 | 12:49 PM
GSRwBOOST's Avatar
use cam gears with as many bolts as you can find... dont use the cheap AEM ones that have 3 or 4, get the ones that have 5 bolts on them.. it will hold better and make sure they are on tight!
Old Jun 28, 2001 | 12:51 PM
Halo's Avatar
Default Re: Cam gears slipping.............? (GSRwBOOST)
I'm already using AEM 3 bolt ones, is there something to do with these that will prevent slippage?
Old Jun 28, 2001 | 01:59 PM
non-VTEC's Avatar
i never accualy seen any cam gears slip weather it's 3 bolts or 10. but personally i feel that if a cam gear slips it's because the tuner did not tighten the bolts enough. i had AEM 3 bolt cam gears and they never slipped. if you want to feel more confortable get skunk2 gears with 6 bolts.
DC Sports relesed new adjustible cam gears as well with i think 6 bolts. Toda and crower has 4 bolts and they both look very good.
my cam gears never slipped. it was a tensioner problem that caused the hell i went through........
Old Jun 28, 2001 | 02:10 PM
Malice's Avatar
New User
what about them?! non-vtec didnt have a gear slip, and FUCATYPR's friend had a guy advance a gear too much. thats not slipping. like i said...its rare. the aems will be fine.i've had them for about 2 years. on my LS..them took them off and put them on my gsr. even if one bolt was lose...u'd still be ok because of inertia effect. slipping gears is most likely install error!
[Modified by MaliceGSR, 12:03 AM 6/29/2001]
Old Jun 28, 2001 | 03:13 PM
berkel's Avatar
My mechanic had the valves bent on my GSR with Toda B specs.
We think the AEM (2 yrs old) Cam gears slipped .
I have very stiff valvesprings (Portflow/ITR) so we think that may have something to do with it.
I had heard of a few people saying their AEMs slipped, but lots of people saying they didn't. I now have a set of the 6 bolt Skunks...
The AEMs were def torqued down, it may be a combination of their wear and the stiffness of the valvetrain.
To take it out of the eqn, I got the Skunks, so I can finally get the car back
Todas also look very nice, and are prob better for adjusting due to the type of markings/scale... I've never heard of Todas or Skunks slipping.
You can def use loc-tite, that should help Halo...
FB
Old Jun 28, 2001 | 03:58 PM
Halo's Avatar
Default Re: Cam gears slipping.............? (non-VTEC)
Will Loctite work on this, I just want to avoid the same problem
Old Jun 28, 2001 | 06:17 PM
non-VTEC's Avatar
the problem i had was not directly the fault of the tensioner. it did not come loose or break or anything like that. it was a stupid mistake i made when i had the cylinder head at the machine shop and told them to mill it .040-.045 (i forgot the exact ammount) well the much taken off the head resulted in the timing belt never being "tight enough" because the tensioner was tensioned all the way and would not take up any more belt slack.
it was only a matter of time before it was going to slip. between the stiff valve springs and the timing belt getting stretched over time that the belt would eventually slip. (yes the timing belt stretches over time)
just a word of advice. do not mill your cylinder head to increase compression more than .030 MAX!!
Old Jun 28, 2001 | 06:54 PM
Halo's Avatar
Thanks non-vtec, I won't. Tell project x I said hi
Old Oct 21, 2016 | 12:19 PM
mattmaine1991's Avatar
My can gears failed what are the known cause???
Old Oct 21, 2016 | 02:43 PM
MotorMouth93's Avatar
10 Year Member
Shitty cam gears or improper bolt torque.
And damn, 15 years.
Old Oct 21, 2016 | 07:29 PM
And damn, 15 years.
bet they are shitty cams. Stick with good ones lol. Haven't look at the internal damage yet. But prepared for the worst.
Skatnshawn
Nov 5, 2012 11:00 AM
The Si
Feb 22, 2007 10:36 PM
94civicexlsvtec
Jul 30, 2005 02:52 PM
DaNish
Nov 9, 2001 08:52 PM
jabroni95gsr
Nov 1, 2001 03:20 PM
