widest tires I can fit?
Old Apr 20, 2003 | 05:58 PM
hatchy's Avatar
Default widest tires I can fit?
What is the widest tires that I can fit under the fenders of a 92 civic hatch?
Old Apr 20, 2003 | 06:12 PM
Kataku2K3's Avatar
Default Re: widest tires I can fit? (hatchy)
I dunno for sure... However the widest I would ever go is 205... Normally 195 is good but then again I hate wheels any bigger than 15's so it keeps the ratio low... Peace
Old Apr 20, 2003 | 06:20 PM
bluedelsol's Avatar
i would also like to know, i have 175's on my del sol right now and it looks like i have 4 little donutes on my car.
Old Apr 20, 2003 | 06:29 PM
hatchy's Avatar
Default Re: widest tires I can fit? (Kataku2K3)
I dont really care what it looks like, I just need a wider contact patch.
Old Apr 20, 2003 | 06:32 PM
Kataku2K3's Avatar
But you care about the wheels rubbing on your fender right.... Again, even 195/50-15's will rub on the fender as will anything bigger so it's up to you... I would still say 205... Sorry if I'm not helping... Latez
Old Apr 20, 2003 | 06:54 PM
bluedelsol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchy &raquo;</TD></TR><TR><TD CLASS="quote">I dont really care what it looks like, I just need a wider contact patch.</TD></TR></TABLE>
i dont what wider tires just for looks, i want better traction on the street where i cant drive with slicks.
Old Apr 20, 2003 | 06:59 PM
J2turbo21's Avatar
Default Re: widest tires I can fit? (bluedelsol)
I think you can put 225's on gsr rims.
Old Apr 20, 2003 | 08:36 PM
hatchy's Avatar
exactly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedelsol &raquo;</TD></TR><TR><TD CLASS="quote">
i dont what wider tires just for looks, i want better traction on the street where i cant drive with slicks.</TD></TR></TABLE>
Old Apr 20, 2003 | 09:40 PM
AllmotorJunkie's Avatar
205 is the widest I have seen on a civic...
Old Apr 20, 2003 | 11:15 PM
eh3 93's Avatar
Default Re: widest tires I can fit? (AllmotorJunkie)
I would just go with the 205's with a +38 or +40 offset. I'm running 205's with a +40 offset and they rubbed in the back and in the front when taking a tight turn so I ended up having to cut the fenders. Everythings fine now.
Old Apr 23, 2003 | 10:02 AM
KOALA YUMMIES's Avatar
Default Re: widest tires I can fit? (J2turbo21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 &raquo;</TD></TR><TR><TD CLASS="quote">I think you can put 225's on gsr rims.</TD></TR></TABLE>
GSR wheels are only 6" wide, I HIGHLY doubt that. On a 6.5" wheel sure.
Old Apr 23, 2003 | 08:31 PM
AWD: Jeff's Avatar
Default Re: widest tires I can fit? (KOALA YUMMIES)
i have 205-15-50, n thats already big and wide enough for me, it scraps on my fenders and my car is pretty high.
Old Apr 23, 2003 | 08:58 PM
real9999's Avatar
Default Re: widest tires I can fit? (Dohc93hatch)
I've seen 315's on a widebody Civic show car. I don't recommend you try it though.
Bruno
Old Apr 23, 2003 | 09:36 PM
careawholelot's Avatar
Default Re: widest tires I can fit? (real9999)
i have 195/50/15 and the back scrapes on turns when i have 2 or more people in my car
Old Apr 24, 2003 | 03:23 AM
jg's Avatar
jg
need more info here. How low is the car? Everything else stock? Splash guards in place? 205/50-15 BFG g-force drag radials will be fine unlees the car is absolutely in the weeds. ...and i've got a set for sale VERY few miles on them...
I have 225/45 15 Hoosier's on my hatch, but definately had to do some "modification" to make them fit.
Old Apr 24, 2003 | 07:29 AM
Jspec_crx's Avatar
how much do u want for them ??...hatchy- i knwo for a fact u can fit 215 on ur hatch i had em on my crx and my bro hatch..
Old Apr 24, 2003 | 08:45 AM
jg's Avatar
jg
Default Re: (Jspec_crx)
they have approx. 8-900 miles on them. Used for motor break-in. I'm going back to 17" wheels. I'm asking $150 shipped.
Old Apr 24, 2003 | 09:26 AM
WOThrilla's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">I dunno for sure... However the widest I would ever go is 205... Normally 195 is good but then again I hate wheels any bigger than 15's so it keeps the ratio low... Peace</TD></TR></TABLE>
-the width of the tire (i.e. 205, 195, etc) is not a ratio. it is simply the measure of the tread of the tire, measured in millimeters. hence a 205 series tire measures 205 mm across the tread length.
-the ratio involved would be the percentage of the sidewall in contrast to the width of the tread and the height of the tire measured from the hub.(i.e. 205 45 16, etc.
-you can usually fit most 215 series tires on 7'' wheels.
Old Apr 24, 2003 | 09:45 AM
Kataku2K3's Avatar
Default Re: widest tires I can fit? (WOThrilla)
Sorry, I wasn't talking about that, I know how tires are sized... I was talkin about the overall diameter ratio... Again I like only 15's with 195/50-55's... That's just me tho... Peace
Old Apr 24, 2003 | 06:42 PM
Jspec_crx's Avatar
i would definetly go 215..better traction and handling...
Old Apr 24, 2003 | 07:01 PM
shermanyang's Avatar
I have 205/50/15 's on all for corners on LS 'webs' and they don't rub at all. great for traction and hard cornering. i didn't want them any wider because of rain and snow here in MN.
BzerFit
Honda Fit
17
Oct 28, 2008 10:39 PM
Chaveli
Jul 31, 2008 02:11 PM
gooberguy31
Apr 16, 2008 03:13 PM
R@mon
Mar 8, 2004 09:36 PM
integranator
Nov 13, 2002 09:10 PM
