Finding the Secondary Intake Solenoid wire
Old Jun 28, 2001 | 11:44 AM
Kalokohan's Avatar
New User
Default Finding the Secondary Intake Solenoid wire
Hey guys I need some help. For the past couple of months, I have using a P28 ECU chipped by Skunk2 on my hybrid 93 hatch with a 2000 GSR motor. Well, recently, I just got a hold of a 95 GSR ECU, I have 6 out of the 7 wires needed to get my car running without throwing codes. The 7th wire is that IAB and the hybrid page says it's the Pink/Blue one. I'm having a problem finding this wire. Can anybody give me a clue on where this wire is located? As you all know, the P28 ECU does not support the IAB, therefore, I never thought to wire it in.
Old Jun 28, 2001 | 10:22 PM
CruZinCiVic's Avatar
New User
Default Re: Finding the Secondary Intake Solenoid wire (Unleashed5GHBGS-R)
move the red wire from A20(EVAP) to A17(IAB). the IAB is pink/blue in the engine compartment but turns to red by the ecu. DO NOT put any positive voltage to that line for any testing purposes or you will burn the IAB in the ecu. run another wire from evap purge to A20 if you havent done so. should be it. good luck
Old Jun 28, 2001 | 11:17 PM
C-speed's Avatar
Are you selling the p28 w/skunk2 program? if so please email me. Thanks.
iamthefollower
Apr 4, 2012 08:32 AM
Civic Hx-T
May 12, 2004 09:21 AM
Eyewitness
Aug 24, 2003 11:39 AM
dingusjt
Feb 11, 2003 07:16 AM
