Questions about spark plug gap and torque?
Old Apr 20, 2003 | 03:47 PM
TimsTeg's Avatar
Default Questions about spark plug gap and torque?
I'm going to install my new NGK spark plugs and i was wondering what the gap is supposed to be. I searched and searched and i couldn't find much about it for 4th gens. Also it says in my repair manual that you have to torque them to 156in/lbs, but all i have is a ft/lbs torque wrench. Anybody know the conversion?
Old Apr 20, 2003 | 04:24 PM
Fastom's Avatar
Default Re: Questions about spark plug gap and torque? (Accord092)
Easy divide by twelve 12 inch pounds equals 1 foot pound
Old Apr 20, 2003 | 06:07 PM
Broman78's Avatar
Default Re: Questions about spark plug gap and torque? (Fastom)
spark plug gap is .44
Old Apr 20, 2003 | 06:58 PM
Mike813's Avatar
i was wondering, does it matter how much you torque it?
cause usually i just use a regular spark plug wrench,
and just tighten it till it feels secure,
but it seems everyone uses the right torque amount,
does this effect anything performance wise etc etc?
thanks..
Old Apr 20, 2003 | 07:02 PM
Nick H's Avatar
New User
Default Re: Questions about spark plug gap and torque? (Mike813)
it won't effect performance at all, but if you overtourque the spark plugs by just goin on what you feel is enough, you may either 1) cause a loss of compression (unlikely) because they aren't tourqued enough...or 2) over-tighten them and you won't be able to get them out next time or stripping etc...use a tourque wrench...it's a great investment!
Old Apr 20, 2003 | 08:51 PM
twkdCD595's Avatar
Default Re: Questions about spark plug gap and torque? (Nick H)
16 ft lbs with a bit of antiseize on each is my opinion.
if you dont have a torque wrench... you need one.
if you really had to do it by hand I would say put one hand on the ratchet closet to the pivoting head/ or holding it even. Then tighten until it becomes difficult to do with one hand and then go a half turn.
remember your head is aluminum and it will not like a plug overtightened into it... save yourself and your threads... it is not a competition to tighten as hard as you can like some think. then they are amazed when they seize something in place or strip/ break a bolt.
Old Apr 20, 2003 | 08:55 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Questions about spark plug gap and torque? (twkdCD595)
ngk plugs are pre gapped. unless they are dropped you dont need to regay them.
it goes like this. that little washer at the end of the threads is gesigned to be crushed. generally, and i use the term loosely, you run the plug down till it has resistence then 3/4 of a turn more will crush that washer. thats what it is there for. and thats it. use never seize if you wish.
zach1288
Aug 5, 2019 05:10 AM
kornerk12
10
Apr 2, 2011 06:03 PM
Coltmorris
Nov 5, 2005 01:53 PM
ralpheezy
Jul 8, 2005 04:49 AM
ebelp
Sep 30, 2002 12:53 PM
