WARNING Jun cams......
Old Jun 28, 2001 | 10:42 AM
ATYPR's Avatar
Default WARNING Jun cams......
Check out these pics of a GSR engine that had Jun cams.
Watch those cam gears!!
[Modified by FUCATYPR, 7:43 PM 6/28/2001]
[Modified by FUCATYPR, 7:49 PM 6/28/2001]
Old Jun 28, 2001 | 11:00 AM
RacerXI's Avatar
Default Re: WARNING Jun cams...... (FUCATYPR)
I knew of another guy running those cams and he also had contact between his valves/pistons. Is that your motor?? That sucks.
Old Jun 28, 2001 | 11:28 AM
Digital-R's Avatar
Your name kills me
Old Jun 28, 2001 | 11:29 AM
kyden's Avatar
dayum!
Old Jun 28, 2001 | 11:33 AM
ATYPR's Avatar
Default Re: WARNING Jun cams...... (RacerSi)
Nope, not mine. The car belongs to a customer.
I love the cams. They made the GSR pull like a truck before VTEC.
Old Jun 28, 2001 | 11:39 AM
ATYPR's Avatar
Default Re: WARNING Jun cams...... (Digital-R)
I got the tag for a buddy of mine who had a ITR. I used to kill his a$$ with my 92 CX.
Old Jun 28, 2001 | 12:06 PM
stretracr's Avatar
Unfortunately that's my car!!!!!!!!!!!!!! That was a sad sad day
[Modified by stretracr, 1:10 PM 6/28/2001]
Old Jun 28, 2001 | 12:37 PM
H23 Power's Avatar
Default Re: WARNING Jun cams...... (stretracr)
explain what happened
Old Jun 28, 2001 | 12:38 PM
Halo's Avatar
what caused that to happen?
Old Jun 28, 2001 | 12:51 PM
stretracr's Avatar
Default Re: WARNING Jun cams...... (Halo)
We dialed in to much duration. You don't have much room for adjustment. Unfortunately I learned the hard way.
Old Jun 28, 2001 | 01:40 PM
ATYPR's Avatar
Look at the cams in the first pic. The left one is a GSR the right one is a JUN.
The numbers were a little low, so the guy at the dyno tried to dail the cams in a little more. He's done 70 or so car before but, this was the first one with the Jun cams.
Old Jun 28, 2001 | 01:42 PM
GQ 05YellowEVO8's Avatar
What do you mean? Did you advance/retard it way too much?
How many degrees, lemme know so that I dont do the same when I tune my Spec B's
Old Jun 28, 2001 | 02:34 PM
slowerthanu's Avatar
New User
Default Re: WARNING Jun cams...... (VTEC-MAN95GSR)
So what is the ******* warning have to do with JUN cam's it should say Warning tuner that doesnt know WTF he is doing
Old Jun 28, 2001 | 03:19 PM
RJL's Avatar
RJL
New User
no offense but, i have jun 3 and you should know by looking at the sick *** ramp angle on the vtec lobe that there isnt much play as far as tuning the cams. I even believe that jun recomends the 0,0 setting on the cams.
Old Jun 28, 2001 | 08:29 PM
ATYPR's Avatar
Default Re: WARNING Jun cams...... (slowerthanu)
DAMN, who pissed in your Coke? I'm just wanted to warn people not to treat high performance cams like the stock ones. Maybe I should keep it to my self and let more people do the same thing.
Old Jun 28, 2001 | 08:41 PM
ATYPR's Avatar
Default Re: WARNING Jun cams...... (Badboy01GSR)
First off, we (me or the tech who installed the pistons) never moved the cam gears.
If they want 0,0, why sell gears? I think the guy at JUN told him it was OK to do some adjustments on the gears.
**** what JUN or anyone else tells you, leave them at 0.
Old Jun 28, 2001 | 08:44 PM
Cru_Jones's Avatar
New User
"Maybe I should keep it to my self and let more people do the same thing."
Theres noting like trial and error!
Old Jun 28, 2001 | 08:59 PM
New User
**** im drinking a Coke right now.
Ok who pissed in my Coke I promise I wont be mad
Old Jun 28, 2001 | 10:22 PM
crookedletterd's Avatar
New User
LOLOLOLOLOL i luv it!
Old Jun 28, 2001 | 10:38 PM
strils's Avatar
Default Re: WARNING Jun cams...... (integls98)
that plate is the shiznit, hahaha
Old Jun 28, 2001 | 11:15 PM
C-speed's Avatar
Default Re: WARNING Jun cams...... (strils)
Man that sucks. I feel for you. However, if you did your research prior to buying or tuning those cams, you would have realized that you can only adjust them +/- 1 deg in either direction before you have contact with the pistons.
You are not the first person this has happened to. I guess some people really like to learn the lesson(s) on their own.
Again, sorry for the misfortune.
Old Jun 29, 2001 | 04:15 AM
stretracr's Avatar
If you don't know what your talking about shut your **** ie. bad boy I talked to jun and they told me 1, .5 for a car with just the cams and i/h/e. The tuner didn't dial much more than that before the contact. And I would be glad to **** in slowerthanu's coke since he is so bright with years of knowledge but doesn't have a clue about comp. Maybe than he'd shut his ****.
[Modified by stretracr, 5:17 AM 6/29/2001]
Old Jun 29, 2001 | 04:22 AM
Dawsonb17a's Avatar
New User
Hey FUCATYPR, where you located in Charlotte man? I live on the south side. Oh, and this is unrelated, but I found out which of my neighbors has the 2001 Lamborghini Diablo VT I've been seeing around!!! Now I just need to meet him somehow
Old Jun 29, 2001 | 05:28 AM
ATYPR's Avatar
slowerthanu, you are FN funny
[Modified by FUCATYPR, 2:35 PM 6/29/2001]
Old Jun 29, 2001 | 05:31 AM
Dawsonb17a's Avatar
New User
Huh?
