Stock Airbox on 94 Accord...
Old Apr 20, 2003 | 02:18 PM
BigChris's Avatar
Default Stock Airbox on 94 Accord...
was wondering if i could remove the bottom part of my stock intake system. it has a solenoid on it with a one way check valve and hosing that goes to the intake manifold. if i do remove this, what should i do with that vacuum line?? if pictures are needed, let me know and i'll post them.
thanks
chris
Old Apr 20, 2003 | 04:57 PM
SOHCMAN's Avatar
Default Re: Stock Airbox on 94 Accord... (BigChris)
I have a 94 accord and I dont have jack on my intake system...no solenoids or anything, unless you mean on the part under the bumper ( havn't taken it out yet)... Pics would help!
Is your car a LEV or a CA model by chance?? thats the only reason I could think you would have extra stuff on there..
sohc
Old Apr 20, 2003 | 05:45 PM
Razor's Avatar
plug the vacuum line with a screw or something, and tape it off to the frame so it won't get in the way. don't worry about any check engines lights going off, it won't happen. that "bottom part" has to do with emissions, don't worry about getting rid of it.
Old Apr 20, 2003 | 05:50 PM
BigChris's Avatar
Default Re: Stock Airbox on 94 Accord... (Razor)
cool.. thanks alot!! i'm gonna post the pictures up just so people can see what i was talking about..
thanks guys
Old Apr 20, 2003 | 06:15 PM
Conechaser's Avatar
Yeah, you just plug it up.
Old Apr 20, 2003 | 08:57 PM
twkdCD595's Avatar
Default Re: (94Accord)
disconnect and remove the box and silinoid... it will have no effect other than the open vaccuum line connection (which you can cap easily with a rubber nipple from the autoparts store).
also there is a resonator box and what not in the fender... that all is junk and can be removed. all it is, is a bunch of dead end and passages for intake air to be routed off.
Old Apr 20, 2003 | 09:36 PM
BigChris's Avatar
Default Re: (twkdCD595)
thanks twkd.. i already had the resonator box out but wasn't too sure about the solenoid and resonator that ran to the IM.
thanks again
Old Apr 21, 2003 | 08:46 AM
SOHCMAN's Avatar
Default Re: (BigChris)
Ha, weird, I had always wandered what that tube was for. The Metal tubes mounted directly behind the intake manifold: My car only has the top one with rubber hoses on it, the one under it(that is for your airbox solenoid) just sits there with nothing routed through it.
lata
sohc
portugueboy10
Apr 2, 2011 07:11 AM
EgK2o09
Feb 26, 2009 05:02 PM
PsychoticClover
Sep 4, 2006 07:31 PM
lahight
Aug 28, 2002 10:03 AM
AccordGuy
Jan 23, 2002 05:58 PM
