Ingalls, Ingalls STYLE, or skunk2 camber kit
Old Apr 20, 2003 | 01:27 PM
VtegGSR's Avatar
Default Ingalls, Ingalls STYLE, or skunk2 camber kit
Hey guys I need a camber kit ASAP, I'm trying to decide which one I should get. I have a 2 inch drop on my car. Should I get the ingalls kit or the skunk2 kit. I heard there are problems with the skunk2 hitting the fender if your dropped low.
Also would I be wasting my money buyin a kit that is just the ingalls Style like this one http://groupbuycenter.com/buy.aspx?id=9466 . any opinions would be very helpful. THanks
Old Apr 20, 2003 | 02:22 PM
MooreBoost's Avatar
Default Re: Ingalls, Ingalls STYLE, or skunk2 camber kit (VtegGSR)
Just buy the Ingalls. You dont want to mess around with knock off parts, especially when it comes to suspension.
gmoore
Old Apr 20, 2003 | 02:24 PM
M-Type's Avatar
Default Re: Ingalls, Ingalls STYLE, or skunk2 camber kit (tegunderpressure)
i heard ingal cambers not completely adjustable, but could be wrong
Old Apr 20, 2003 | 02:27 PM
MooreBoost's Avatar
Default Re: Ingalls, Ingalls STYLE, or skunk2 camber kit (M-Type)
I have H&R Race springs hunkered over Koni 5-ways, Im pretty low needless to say with Ingalls kits and I have correct camber.
gmoore
Old Apr 20, 2003 | 02:40 PM
VtegGSR's Avatar
So you think the Ingalls no name brand isn't gonna be worth it?
Old Apr 20, 2003 | 03:04 PM
CNSK's Avatar
I recommend skunk2, i installed it in my civic and it's way better then ingalls. I have ingalls in my other teg and the camber works well also, but it damage my inside a little.
Here's a picture with my ingalls and what it did to my car.
Old Apr 20, 2003 | 03:56 PM
MooreBoost's Avatar
Default Re: Ingalls, Ingalls STYLE, or skunk2 camber kit (DrMartin)
Yes, that can happen.
gmoore
Old Apr 20, 2003 | 05:28 PM
P1mpSlap's Avatar
Yeah, I recommend sunk2 also. I had it on my civic. No problems what so ever.
I've heard horror stories about clearence issues with the Ingalls kit.
Old Apr 20, 2003 | 05:33 PM
Hairy Gorilla's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrMartin &raquo;</TD></TR><TR><TD CLASS="quote">I recommend skunk2, i installed it in my civic and it's way better then ingalls. I have ingalls in my other teg and the camber works well also, but it damage my inside a little.
Glad I got my skunk 2 kit. Any tips on installing? I looked at it today w/ the wheel off and it looked a little confusing on my 99 gsr.
Old Apr 20, 2003 | 07:48 PM
VtegGSR's Avatar
WHat is that from?
Old Apr 20, 2003 | 07:51 PM
animated_life's Avatar
yes i would like to know too....how did the ingalls kit cause that rusting / puckering on your car?
Old Apr 20, 2003 | 07:53 PM
arsenaldragster's Avatar
what is that from?
Old Apr 20, 2003 | 08:32 PM
LSvtec03's Avatar
i have the ingalls. i have no idea how a set of these could have done that to DrMartins car, but ive had no problems with them whatsoever.
Old Apr 20, 2003 | 11:08 PM
tC_Dragon's Avatar
Default Re: Ingalls, Ingalls STYLE, or skunk2 camber kit (LSvtec03)
skunk2 gets my vote
I have it on my car and have had it on their for more than 4k miles now and i've had no problems whatsoever.... no abnormal squeeking issues either like some people complain about other kits. oh and if you need help on the install go here...
http://student.ucr.edu/~ohe02 and go to the diy section. Its my site, i put that install guide together to help peeps out.
Old Apr 20, 2003 | 11:55 PM
tC_Dragon's Avatar
Default Re: Ingalls, Ingalls STYLE, or skunk2 camber kit (typeR0059)
ingalls replaces the stock upper links that connect the upper A arms to the strut tower.... while the skunk2 kit replaces instead the upper A arm and the integrated ball joint. So the camber adjustment is made at a slightly differnt point. The skunk2 kit is fully adjustable from +4deg to -4deg according to them and they do this by having the ball joint mounted on a track on teh upper a arm so that it can be moved in or away from the center of the car and thus correcting or adjusting the camber.
Old Apr 21, 2003 | 12:44 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Ingalls, Ingalls STYLE, or skunk2 camber kit (pdcdragon)
I hope all you guys w/ camber kits aren't getting them set to straight up 0 camber. If so you are hurting the car's handling abilities. If I were you I would run it somewhere between -1.5 to -2 deg. I run -2.3 w/o a camber kit w/o problems.
Old Apr 21, 2003 | 12:47 AM
CWESTINAP1's Avatar
i have an ingalls front camber kit and rear if anyone is interested.
Old Apr 21, 2003 | 01:13 AM
XDEep's Avatar
Default Re: Ingalls, Ingalls STYLE, or skunk2 camber kit (CWESTINDC2)
if you get an ingalls clone, make sure it comes with the bushings. mine didnt and it bent my upper a-arm. had to make my own bushings..
Old Apr 21, 2003 | 10:57 AM
Default Re: Ingalls, Ingalls STYLE, or skunk2 camber kit (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I hope all you guys w/ camber kits aren't getting them set to straight up 0 camber. If so you are hurting the car's handling abilities. If I were you I would run it somewhere between -1.5 to -2 deg. I run -2.3 w/o a camber kit w/o problems.</TD></TR></TABLE>
Wouldn't it be a waste of money even buying a kit if you were still gonna run -2 degrees of camber? Should the rear be set at 0 or should you also leave some negative camber there? It seemed to me that the rear is closer to 0 degrees after my drop than the front is(front has much more neg camber).
Old Apr 21, 2003 | 11:39 AM
tC_Dragon's Avatar
Default Re: Ingalls, Ingalls STYLE, or skunk2 camber kit (Tim Maryak)
yea, its normal for ur camber to be worse in the front after u drop it... our tegs seem to do that...
Old Apr 21, 2003 | 11:52 AM
Malice's Avatar
New User
how the hell did a camber kit do that?!
BTW the skunk2 gets my vote too. installing and alignment for me on Saturday
Old Apr 21, 2003 | 12:18 PM
daewonder.'s Avatar
Default Re: Ingalls, Ingalls STYLE, or skunk2 camber kit (MaliceGSR)
^^ Ingalls did that to my car too.
can anyone explain why this happens??
Old Apr 21, 2003 | 12:30 PM
tC_Dragon's Avatar
Default Re: Ingalls, Ingalls STYLE, or skunk2 camber kit (B18Chillin)
from the looks of it... the upper A arm probably knocks the strut tower from the underside of it and causes the paint to crack off.
Old Apr 21, 2003 | 12:33 PM
daewonder.'s Avatar
would it be worth it to swap out for a skunk2 kit or maybe just swap the front if possible?
Old Apr 21, 2003 | 12:35 PM
tC_Dragon's Avatar
skunk2 only makes a kit for the front, nothing for the rear, and ultimately the decision to switch is up to you... i'm happy with my skunk2, but have not had experience with the ingalls so i wouldnt be able to give you a comparison review... but on a side note, i have not a single problem with my skunk2 so far so i'm happy with it.
