help air fuel gauge problems!!!
Old Apr 20, 2003 | 09:18 AM
Yellb16crxsi's Avatar
Default help air fuel gauge problems!!!
hey i am installing an air/fuel gauge(autometer). and i hooked the purple wire to the white wire on the very lowest connector on a pr3. is this right i thought you were supposed to hook it up on the o2 sensor wire on the ecu. but all the gauge does is sit at 1 led all the way on the rich side. does anyone know what is wrong
Old Apr 20, 2003 | 09:45 AM
bfrank81's Avatar
Default Re: help air fuel gauge problems!!! (Yellb16crxsi)
http://www.autometer.com/hp/in...j.pdf
This may help!
Old Apr 20, 2003 | 11:01 AM
now i have hookes it up to both c16 and c8 and they both give me the same led lit up.
Old Apr 20, 2003 | 12:40 PM
MADEINIRAQ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yellb16crxsi &raquo;</TD></TR><TR><TD CLASS="quote">n/m it works now.......</TD></TR></TABLE>
yeah, you have to drive it a little to warm it up... a search should have cleared up this problem.
Old Apr 20, 2003 | 01:59 PM
Default Re: help air fuel gauge problems!!! (madeiniraq)
on me for not searching enough!
Old Apr 20, 2003 | 03:32 PM
grrr now it is not working.... when i put on my running lights it moves to lean then if i put my headlights on it goes more lean and if i use my turn signal it will go lean when the arrow on the cluster comes on and i have the power for the gauge hooked up to the radio power and then i have the o2 sensor hooked up at the #1 o2 c16 on my pr3 ecu why isw it doing this?
Modified by Yellb16crxsi at 3:40 AM 4/21/2003
Old Apr 20, 2003 | 06:56 PM
MADEINIRAQ's Avatar
where are you grounding it?
Old Apr 21, 2003 | 03:56 AM
i am using the radio ground....... is this an ok spot to ground?
i will take a few pics of what it does when i come home for school....arrgghhh schooool.......
Old Apr 21, 2003 | 05:04 AM
1.8Tities's Avatar
Yeah, make sure you let car warm up and drive it around. It should work.
Now for your second problem: You are having some major interference problem, I would suggest taking that ground out and connect it to you battery ground. That's what I did and it works great. No interference at all.
Old Apr 21, 2003 | 05:30 AM
zCivic's Avatar
Default Re: help air fuel gauge problems!!! (4thGSi)
I always ran the 02 wire from the 02 directly about 6''s back. Run a dedicated wire for it then a good ground. Now when you turn on radio, headlights, or anything electrical it will move it a little leaner because there LED lights and they also run off of 12volts and its extra drains on your electrical. When setting A/F make sure nothing is on and that will be as true as a narrow band 02 will get
Old Apr 21, 2003 | 09:31 AM
Default Re: help air fuel gauge problems!!! (zCivic)
so for all of you the gauge will read leaner if you cut on any electical stuff?
Old Apr 21, 2003 | 11:25 AM
zCivic's Avatar
yes because its getting lesser voltage....same way you radio or headlights will dim if you have a large system with a large amp when ever the bass hits
Old Apr 21, 2003 | 12:30 PM
Timmah!!'s Avatar
https://honda-tech.com/zerothread?id=470991
that should help you
93boostedcivic93
Jul 15, 2007 10:33 PM
mortificationrock
May 20, 2007 08:56 AM
bmiller17
Jan 24, 2006 02:32 PM
90 Si Hatch
Dec 10, 2004 05:07 PM
