opinions needed on my motor buildup please!!!!!!
Old Apr 20, 2003 | 08:45 AM
Chugger's Avatar
Default opinions needed on my motor buildup please!!!!!!
to start i have a jdm b18c with a skunk2 im, itr tb, toda b's, skunk2 chipped p28
i plan to build a bottomend consisting of
b18c block
balanced b18a crank and rods usind arp rod bolts
.25 overbore ctr pistons
gsr head (portflow)
portflow valvetrain
toda b's
this will be ran with hondata
is there anything you would add or that you would take away
thanks
chris
Old Apr 20, 2003 | 09:26 AM
earl's Avatar
Default Re: opinions needed on my motor buildup please!!!!!! (Chugger)
looks like a good starting place. The rods could be the weak spot as the engine should rpm quickly with that head.
Old Apr 20, 2003 | 10:56 AM
joe_bocc's Avatar
I'm curious why you are going to run the LS crank and rods in the GSR crank. Is it for the extra stroke?
IMO, the extra 1.8mm of stroke would not be worth the extra work to buy it and put it in.
Old Apr 20, 2003 | 11:16 AM
TRENDSETTLER's Avatar
Default Re: opinions needed on my motor buildup please!!!!!! (joe_bocc)
sounds like a pretty good setup
are you plannin on using the b18a stuff for extra stroke or other reasons?
sounds good though...toda bs
Old Apr 20, 2003 | 07:17 PM
Chugger's Avatar
Default Re: opinions needed on my motor buildup please!!!!!! (TRENDSETTLER)
let me reming you that this is a somewhat budget buildup. hehe wish i could get better stuff but i believe this will do me just fine.
i am using the ls guts cause of the stroke yes and to try something different.
i am getting the crank and rods for basically free and the block almost the same.
i know ls/vtecs make good power with a broader band than than a reg. gsr.
i get tired of revving the **** out of my motor. why not make the same if not more power at a lower rpm.
the portflow head will come later i will be using a stock gsr head for the time being
with the toda b's and other goodies i want to build the bottom end then do the head.
any more opinions this is really helpful to me.
i was told by a very reliable source that the ls rods will do just fine and have witnessed them hold up in many applications.
i was wondering on micropolishing is this a necessity?
thanks again
lata
chris
OneHondaDollar
25
Dec 10, 2011 07:34 PM
dytech
Apr 9, 2010 02:05 PM
youre_scum
Aug 10, 2007 04:02 PM
pornstar4777
Apr 19, 2006 03:15 PM
4g4drb17
23
Mar 15, 2006 06:23 PM
