idle problems and squeek after skunk 2 cam install and new dizzy
Old Apr 20, 2003 | 06:59 AM
riceboyEFsi's Avatar
Default idle problems and squeek after skunk 2 cam install and new dizzy
installed my skunk 2 stage2's and put a new dizzy in . The car will not idle unless i hold the gas around 2000-3000 rpms otherwise it will stall. Just also installed a vafc , could it have any thing to do w/ settings on it ? There is also a weird squeek coming from either the timing belt or alt. belt . Any 1? thanx>>> e
Old Apr 20, 2003 | 07:15 AM
acatak's Avatar
Default Re: idle problems and squeek after skunk 2 cam install and new dizzy (riceboyEFsi)
Make sure your timing belt isnt off a tooth
Old Apr 20, 2003 | 07:16 AM
Default Re: idle problems and squeek after skunk 2 cam install and new dizzy (acatak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acatak &raquo;</TD></TR><TR><TD CLASS="quote">Make sure your timing belt isnt off a tooth</TD></TR></TABLE>
Its dead on
Old Apr 20, 2003 | 08:41 AM
StinkyTofu's Avatar
Did your cam gears slip?
Old Apr 20, 2003 | 08:47 AM
Default Re: idle problems and squeek after skunk 2 cam install and new dizzy (StinkyTofu)
nope everything is cool w/ the gears
Old Apr 20, 2003 | 12:20 PM
im starting to think the squeek i here is from the the bering inside the dizzy going bad
Alli
Apr 20, 2012 05:51 AM
civicstar
Apr 16, 2009 07:43 PM
-Championship-
Aug 5, 2006 09:06 PM
PatrickGSR94
Apr 11, 2003 04:21 PM
batboyvaj
Jul 22, 2002 07:53 PM
