Hondata IM gasket,worth it?
is i worth it to by this over an oem? also ive seen people ste it up for race or street use by cutting a hole in the side or leaving it closed. please explain
If youre replacing the IM gasket anyway, you should DEFINITELY go with a Hondata gasket. It is extremely efficient.
On the race gasket, the TB bypass is blocked off if you have performed the TB coolant bypass "trick" on your car. This sometimes leads to rough idle, which is why its a "race" manifold. Unless you have done the coolant bypass, youll need the street gasket.
