Integra GS-R Owners!! I need help inside!!
Old Apr 19, 2003 | 10:23 PM
B00ST2nR's Avatar
Default Integra GS-R Owners!! I need help inside!!
Ok. I have a breather filter on my valve cover, instead of the tube from the AEM Intake nipple.
I heard its illegal and not good for the car, so I wanted to take off the breather filter.
Anyways, I didn't do the Skunk2 IM install. A friend of mine did it, and it seems he connected the Intake nipple hose to some weird device that I don't know of.
What is that thing? Will something bad happen if I take the hose off and put it on the Breather?
What is that hose connected to and what purpose does it serve?
How am I suppose to take the Breather filter off and replace it with the Intake nipple hose when its connected to that weird thing?
Someone help me out. Thanks.
Old Apr 19, 2003 | 10:27 PM
ragejed's Avatar
Default Re: Integra GS-R Owners!! I need help inside!! (Skunk2nR)
rip that crap off man.
Old Apr 19, 2003 | 10:28 PM
B00ST2nR's Avatar
Default Re: Integra GS-R Owners!! I need help inside!! (ragejed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragejed &raquo;</TD></TR><TR><TD CLASS="quote">rip that crap off man.</TD></TR></TABLE>
well what is it? What does it do? Will something **** up if I just take the hose off and put it on the Breather?
Old Apr 19, 2003 | 10:35 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
no
Old Apr 19, 2003 | 10:36 PM
B00ST2nR's Avatar
Default Re: Integra GS-R Owners!! I need help inside!! (dLo GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dLo GSR &raquo;</TD></TR><TR><TD CLASS="quote">no</TD></TR></TABLE>
Do you know what it is Ryan?
Old Apr 20, 2003 | 02:01 AM
RacerZook's Avatar
What's that other hose run to? The Hose below the one you highlighted on the part in question?
Old Apr 20, 2003 | 02:13 AM
BlkGSR's Avatar
Default Re: Integra GS-R Owners!! I need help inside!! (RacerZook)
i believe it is a filter. Similar to a protein skimmer.
Old Apr 20, 2003 | 03:15 AM
HiRevn's Avatar
Default Re: Integra GS-R Owners!! I need help inside!! (BlkGSR)
I would just take that thing off.
Old Apr 20, 2003 | 06:51 AM
vain's Avatar
i can't tell very well.. that little thing you have circled (2nd picture) .. does it have 2 hoses (1 in, 1 out?) coming out of it? that thing doesn't look like it does anything.. one hose is coming from the intake right? where's the other hose going (if there's 2)?
Old Apr 20, 2003 | 07:43 AM
MooreBoost's Avatar
Default Re: Integra GS-R Owners!! I need help inside!! (vain)
It kinda looks like my map sensor.
gmoore
Old Apr 20, 2003 | 08:03 AM
BluFire's Avatar
Default Re: Integra GS-R Owners!! I need help inside!! (tegunderpressure)
Thats weird man, Id say the hose isnt serving any purpose at all since its SUPPOSED to be hooked onto the valve cover putting air back in the intake. Unless that "box" is giving off air pressure I cant see it doing anything the way it is set up..
See, I have the S2 manifold too and I have no idea what your **** is hooked onto, haha
Old Apr 20, 2003 | 08:48 AM
VTEC-DA's Avatar
Default Re: Integra GS-R Owners!! I need help inside!! (BluFire)
I have done a couple S2 manifold installs and I have never done that. The nipple always goes back to the valve cover. Always. Not too sure what your friend did.
Old Apr 20, 2003 | 09:06 AM
VTECorona's Avatar
Default Re: Integra GS-R Owners!! I need help inside!! (VTEC-DA)
It looks like that came from elsewhere in your engine bay by the looks of those 2 mounting holes with the circle fade around them.
Old Apr 20, 2003 | 09:44 AM
DeDonDeRosa's Avatar
Default Re: Integra GS-R Owners!! I need help inside!! (97RedTegGSR)
thats is the Purge Valve Sylinoid but i have no clue why its conected to that
thats weird
Old Apr 20, 2003 | 10:59 AM
PaChiLa Leader's Avatar
Default Re: Integra GS-R Owners!! I need help inside!! (DeDonDeRosa)
dont' know what that is, but i would say take it off
Old Apr 20, 2003 | 11:45 AM
neo1z's Avatar
Default Re: Integra GS-R Owners!! I need help inside!! (PaChiLa Leader)
Jun -- Im really confused by that little box guy...Im trying to figure out if thats where I put a T fitting or not...hmm.
Either way --- that breather filter does need to go.
Im going to go look at mine and Ill get back to you.
Old Apr 20, 2003 | 11:56 AM
B00ST2nR's Avatar
Default Re: Integra GS-R Owners!! I need help inside!! (neo1z)
Damn...
Someone find me a solution.
My ultimate questions is:
Can I just take that hose off and put it on the breather? And leave that opening, open?
Will it mess anything up? What is SUPPOSE to be hooked up to that device, if not the intake nipple hose??
Old Apr 20, 2003 | 12:00 PM
B00ST2nR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeDonDeRosa &raquo;</TD></TR><TR><TD CLASS="quote">thats is the Purge Valve Sylinoid but i have no clue why its conected to that
thats weird</TD></TR></TABLE>
What does the Purge Valve Sylinoid do? And will anything mess up if I just unplug that hose and run it to the breather?
What originally connected to that device, if not the intake hose?
Old Apr 20, 2003 | 01:29 PM
TegLover4life
Guest
Posts: n/a
Ask your friend what he did and then you might get a better idea. Good luck hehe i am getting an intake soon.
Old Apr 20, 2003 | 01:53 PM
alfaaay's Avatar
Default Re: Integra GS-R Owners!! I need help inside!! (TegLover4life)
I know next to nothing about your problem, but I do have a suggestion. If you're worried about it and want to switch the hose, put the breather filter on the thing that the hose is hooked up to and connect the hose to the valve cover.
Old Apr 20, 2003 | 02:10 PM
Evilteg's Avatar
who cares if its illegal. leave the breather on, and get a rubber nipple plug for the unused portion on the intake piping.
Old Apr 20, 2003 | 02:20 PM
Default Re: Integra GS-R Owners!! I need help inside!! (alfaaay)
its number 5 on here
http://www.acuraautomotivepart...82%29
go here
its goes to your evap canister
Old Apr 20, 2003 | 02:28 PM
M-Type's Avatar
stock breather line connect directly to the intake piping. so even if you have a skunk2 intake mani, it shouldnt be any different, you can take it off and connect it directly to your valve cover. If it does go to the charcole cani i just plug it up
Old Apr 20, 2003 | 02:30 PM
M-Type's Avatar
Default Re: Integra GS-R Owners!! I need help inside!! (M-Type)
i'm suprise how you can close your hood with that throttle cable bracket
Old Apr 20, 2003 | 10:05 PM
B00ST2nR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeDonDeRosa &raquo;</TD></TR><TR><TD CLASS="quote">its number 5 on here
go here
Will something bad happen if I disconnect it and leave it open?
