4DR integra owners... do your windows whistle on the highway?
If so, how the hell do you fix it? I had to deal with it for a 6 hr drive today. Does the window need shimming or something? I need a solution for this problem.
My front passanger side whistles sometimes, because some numbskull pryed the door frame open so they could pull the window out to unlock doors (thieves and frameless windows
), so now if the windows up all the way and you shut the door it goes ontop of that seal on the top of the door frame, so I have to roll down about 1/2" then roll it back up. Otherwise, you might just want to check the seals up top.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Westrock2000 »</TD></TR><TR><TD CLASS="quote">My front passanger side whistles sometimes, because some numbskull pryed the door frame open so they could pull the window out to unlock doors (thieves and frameless windows
), so now if the windows up all the way and you shut the door it goes ontop of that seal on the top of the door frame, so I have to roll down about 1/2" then roll it back up. Otherwise, you might just want to check the seals up top.</TD></TR></TABLE>
same problem here. car was stolen some years back before i owned car, but it does it on all the windows anyway. i have to roll down all opened windows and close em again to get it to be "ok"...
), so now if the windows up all the way and you shut the door it goes ontop of that seal on the top of the door frame, so I have to roll down about 1/2" then roll it back up. Otherwise, you might just want to check the seals up top.</TD></TR></TABLE>same problem here. car was stolen some years back before i owned car, but it does it on all the windows anyway. i have to roll down all opened windows and close em again to get it to be "ok"...
I've found that if you open the back window a little it creates a vaccuum on the front window when you roll it up and seals it up a little better. I only have to use this trick sometimes on the messed up one that was pryed open.
interesting i must try that. My rear drivers side whistles. when i replaced my weather stripping the window didnt exactly align with the new stripping. my freind said i have to re adjust the window.
perfect?...not mine... i have had no theft damage... yet the window whistles like crazy. i have to move it up and down until the whistling stops... . when set like this, it sometimes leaks too... WTF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garados »</TD></TR><TR><TD CLASS="quote">Mine do this as well, just roll it up and down until it stops.</TD></TR></TABLE>
Exactly, just crack it and close it again that usually works for me.
my passenger side whisltes when someone opens the door and gets in. i have to put the wintow down a crack, then back up. And my kumahos are freakin loud too
4-door pride!!!!!!
4-door pride!!!!!!
umm try to recondition the rubbers to it will be a bit softer and it should flex a little more so the rubber will give a little more instead of the window... works for me.. i just slap on some armor all on it.. i love my 98 4dr gsr
even more when i stuck my s2k seats in them eheheh
You might try adjusting them, you take the door panles off then you will see two bolts on the top of the door frame you can adjusts the window in or out. It sounds like you need to move them in! trial and error! but look at how they sit in the seals, I messed with mine and they dont make any noise now..you might also look into lube'n the rails up while you have the panels off! but use somthing that has no smell!
good luck!
good luck!
I've got that same problem in my 2dr LS and I just open and close them when I use the doors.
), so now if the windows up all the way and you shut the door it goes ontop of that seal on the top of the door frame, so I have to roll down about 1/2" then roll it back up. Otherwise, you might just want to check the seals up top.</TD></TR></TABLE>I've got that same problem in my 2dr LS and I just open and close them when I use the doors.
JamesV
Jun 21, 2006 04:07 PM
HGZ
Aug 13, 2004 02:58 PM
