std to si swap i need help fast
ok the motor is wired it cranks and has fuel.i have a questionable pg7.will that cause it not to have spark?im going to try a new distributor tomorrow. any other ideas let me know
if u have a vacum advanced ignition PG7 wich its from 86-87 integras the ecu will not work...
i had one and still have it here and doesnt work..... check the date stamp on the ecu .... should be 88- or 89 if not then u have a non functional ecu
When I did my MPFI swap, the si dizzy that I got had a bad Ignitor. Pull the dizzy apart and make sure all of the internal conections are secure, the wires that conect to the ignitor get loose sometimes.
Afshin9393
13
Mar 4, 2011 12:40 AM
EK-Bpower
Aug 2, 2008 12:25 PM
