Wiring a dash mount LED?
Old Apr 19, 2003 | 08:39 PM
civic_91's Avatar
Default Wiring a dash mount LED?
HEy can someone tell me how to wire a dash led scanner... i have it installed but i want to set it up so that it turns on when the ignition is off and when i start the car it turns off... can someone help me with this please ? thank you diagrams will help as well
Old Apr 20, 2003 | 05:17 AM
Xsi's Avatar
Xsi
Default Re: Wiring a dash mount LED? (civic_91)
Buy a 5 pin relay
Hook pin 30 to a constant power +
Hook pin 85 th an earth -
Hook pin 86 to a 12 volt power supply that is on when you have the ignition on.
Hook pin 87A to your led
This is presuming you led can take 12 volts, it may be something like 5V in which case 12V would blow it
Old Apr 20, 2003 | 05:55 AM
rjr162's Avatar
Default Re: Wiring a dash mount LED? (Xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi &raquo;</TD></TR><TR><TD CLASS="quote">Buy a 5 pin relay
This is presuming you led can take 12 volts, it may be something like 5V in which case 12V would blow it</TD></TR></TABLE>
If i can remember correctly, i believe all the led scanners have built in resistors... so the 12v's is fine
Old Apr 20, 2003 | 09:00 PM
Xsi's Avatar
Xsi
Default Re: Wiring a dash mount LED? (rjr162)
Now that you mention it I've heard some of them some with a relay built in so you would only need to hook up three wires, check the instructions.
Old May 18, 2003 | 09:24 AM
1.8T_EG's Avatar
what resistors would be needed to ensure that a 5v led will not blow from a 12v source?
Old May 18, 2003 | 10:57 AM
EGPrelude's Avatar
there should be three wires, red, blk, and another color (don't remember the color) and I believe you just hook up the last wire to the ignition wire
footstinker
Jul 7, 2010 10:58 AM
Un0Turb0-WP
Jan 4, 2005 06:16 AM
DOHCRX
Aug 10, 2003 04:31 AM
1.8T_EG
Mar 17, 2003 05:04 PM
hagrid
Audio / Security / Video
Jan 7, 2003 09:15 AM
