Squeek in the GSR :(
Old Apr 19, 2003 | 08:28 PM
Hairy Gorilla's Avatar
Default Squeek in the GSR :(
For the past while I have been hearing this squeek in the GSR from the engine bay area. I have a 99 GSR. I notice it only when I sit idling. It sounds just like a belt squeeking, but I found out that right when I push the clutch in the sound disappears. When I release the clutch it is right back. This happens maybe 50% of the time I idle. Very freaking annoying. It must not be a belt then. Someone please help me out. Something to lube...ERRRRRR
Old Apr 19, 2003 | 09:13 PM
fiebru1119's Avatar
Default Re: Squeek in the GSR :( (Tim Maryak)
If its clutch related, I'd put my money on the throw out bearing.. but check your belts first. If its not the release bearing, it might be the bearings in the tranny (had to have mine replaced at 55K miles).
Mine sounded like almost grinding a metal knife against a metal plate or something... engage and disengage the clutch. I would hear a faint *clack* then the sound would come back when I let go of the clutch pedal..
Old Apr 20, 2003 | 10:30 AM
Mike G.'s Avatar
Default Re: Squeek in the GSR :( (fiebru1119)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fiebru1119 &raquo;</TD></TR><TR><TD CLASS="quote">If its clutch related, I'd put my money on the throw out bearing..
Agreed, it's a fairly common problem.
Old Apr 20, 2003 | 10:49 AM
VTECorona's Avatar
Default Re: Squeek in the GSR :( (Mike G.)
I get a really low pitch whistle noise, I have a feeling it's a belt. I brought it to acura once about it and they tightened up my alt. belt and it went away. But low and behold it's back. They didn't charge me to tighten it so I'm not gonna bitch about it
Old Apr 20, 2003 | 12:02 PM
M-Type's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike G. &raquo;</TD></TR><TR><TD CLASS="quote">
Agreed, it's a fairly common problem.</TD></TR></TABLE>
yea thats what i think too, just barely put your foot on the clutch and see if it goes away
Old Apr 20, 2003 | 12:14 PM
GSRdriver's Avatar
Default Re: Squeek in the GSR :( (M-Type)
Same with mine, but Acura wants me to authorize a tech to look at it then they are going to determine if its warrantable ?? If its not then I have to pay the $300 plus dollars just to look at it, then I need to decide if I want them to do it. Which means more money.
They told me something like "if they find that the vehicle has been driven aggressivly, such as hot spots on the cluth or something like that, they are not going to warrenty it". Now I don't even drive the car hard anymore. I wonder if I shold just have them look at hit and have my mechanic look at it if I have any problems. They also think its the throw out bearning.
If you barly put you foot on the clutch and it goes away thats what I'd say is the problem.
Old Apr 20, 2003 | 12:18 PM
Default Re: Squeek in the GSR :( (GSRdriver)
Yea I can just barely touch teh clutch and it goes away. If that means it is the throw out bearing, how much would I be looking at for the fix? It sounds common in manual transmisions...
Old Apr 20, 2003 | 12:20 PM
jcm3's Avatar
It's pretty easy to take out the tranny and check the condition of the throw out bearing if you have a few tools and a place to do the job....
I would buy a manual and give it a shot if you can have the down time with your car....
If you follow the manual it should be able to come apart and go back together in a day... at the longest a weekend!
It doesn't make sense to pay someone 300 plus dollars to look at a part that costs about 25...
Have faith and a little patients and you should be able to do it and not get raped by the damn flat raters at the dealership...
BTW if your a dealership mechanic reading this... no offense but you know what you charge and how much it really should cost I am a flat rater myself
Old Apr 20, 2003 | 12:54 PM
M-Type's Avatar
Default Re: Squeek in the GSR :( (jcm3)
i have the same problem and i'm planing to get a new clutch sooon and hope this goes away
Old Apr 20, 2003 | 02:35 PM
fiebru1119's Avatar
The throwout bearing runs around $45. You dont have to pull the motor, just drop the tranny. While you are down there, you might want to go ahead and check the condition of the clutch and get that replaced (or upgraded) at the same time. For the DIY'er, its no too bad, no special tools needed really...
Old Apr 20, 2003 | 05:39 PM
Yea I was telling my dad about the problem earlier and he was asking if there is anything else I should go ahead and replace while I was in there, if we did it ourselves or if we took it to a shop. No problems w/ gears grinding so I think syncros are good. When we do it I would probably switch clutch too since the car does have 50k miles.
Old Apr 20, 2003 | 08:22 PM
T3T495GSR's Avatar
i just noticed a similar problem yesterday, when i back up and let off the clutch i hearing a knife going against a plate sound too, but it sounds like its coming from the right rear which there is blown shock there too HMMMMMMMMM
dtran002
Feb 1, 2013 06:02 AM
5.56
Jan 17, 2009 06:32 PM
ultima.maniac
Jun 10, 2008 06:09 PM
EliTe 93Lude
Jul 27, 2006 06:58 AM
Si_Allen
Jan 15, 2005 05:24 PM
