D15Z1 head on a D16y7 motor YES or NO
Old Apr 19, 2003 | 06:21 PM
SCsol's Avatar
Default D15Z1 head on a D16y7 motor YES or NO
Will a D15Z1 head (1.5 sohc vtec) work with a D16y7 motor for a mini-me swap?
If so what will i need?
Is this head D15Z1 the same or close to a Z6 or a Y8 head?
Any help would be great. Thanks
Old Apr 19, 2003 | 06:32 PM
orange.honda's Avatar
Default Re: D15Z1 head on a D16y7 motor YES or NO (SCsol)
it will work. but i dont know why you would do that. it has vtec-e not vtec-p. that means it is very economical. not the best to sup up. but if you run another cam and tune the vtec then yea it should be better. i would save your cash and buy a y8 or z6 head it is worth the cash.
Old Apr 19, 2003 | 06:36 PM
SCsol's Avatar
Default Re: D15Z1 head on a D16y7 motor YES or NO (orange.honda)
Well its going in my GF car. So HP is not a big deal!!!! But i do have the VX motor with the head in the car now but its burning oil pretty good. And I also have a D16y7 motor to be put in it. I just dont feel like finding another ECU so it would almost be just as easy to do the swap.
What parts do i need? And does any one know the final C/R from the motor. Is there a C/R chart to look at for these motor swaps?
Thanks any help would be great
Old Apr 19, 2003 | 06:42 PM
http://www.knology.net/~jediklc/D.htm
thats the best i can do. but it doesn't have the combo you want.
Old Apr 19, 2003 | 06:44 PM
SCsol's Avatar
does any one know the cc'svolume of the Z1 head compared to the cc's volume of the Z6 or the y8 head? Any help would be great so i can use it with orange.honda's chart he was nice enough to find me.
Old Apr 19, 2003 | 06:50 PM
SCsol's Avatar
does any one know the Piston Dome Displacement (cc per piston) for a
P2E-000 (USDM D16Y7) pistion
Old Apr 19, 2003 | 06:51 PM
http://www.heeltoeauto.com/dseries/dseries1.html
this should help, i think
Old Apr 19, 2003 | 06:53 PM
SCsol's Avatar
does this sound right
P2E 50.00 30.00 3.32 Dish a 3.32 cc dish for the pistions??
Old Apr 19, 2003 | 06:59 PM
SCsol's Avatar
ok if the VX pistions have 7.05mm dish with a CR of 9.3to1
92-95 Civic VX D15Z1 1493cc
4 cyl, 16 valve
SOHC VTEC-E
9.3:1 c.r.
PGM-FI (MPFI)
using a 3.32mm dish woudint it make a CR of 10.657796861089744to1
How street able is this? what Hp do you think it will make?
And will i need to put APR studs in? (remmber its the GF's car) but i will use it to beat the freinds!!!!
Old Apr 19, 2003 | 08:27 PM
SCsol's Avatar
What head bolts do i use? The Z1 or the Y7? Im using the Y8 head gasket. to get a CR of 10.47698067334861 to1!!!!
What cams can i put in this motor? Z6, Y8?? Will they work in this head?
What timing belt do i use?
Is 11to1 compression too much for daily driving on 89 oct gas?
Old Apr 20, 2003 | 10:13 AM
SCsol's Avatar
Does some one know what parts to use? Please help if you know thanks
Old Apr 20, 2003 | 12:09 PM
run the highest octane you u can 11:1 is pretty high but still streetable. out here in ca i can get 92 at arco. run at least 91. you shouldn't nneed after market studs or anything, but you should replace the head bolts with new ones.
Old Apr 21, 2003 | 11:18 AM
SCsol's Avatar
Ok what about 10.6 to 1 with the timing around stock and driving it normal on the streets. Will i be Ok with 89 OCT gas??? OR is the 1.6 to 1 still too much? Is only a lillte more than a SI motor compression!!!
Tinoo
10
Feb 3, 2011 04:55 PM
Cras-Delsol
15
Sep 19, 2008 09:39 PM
joebobkabila
Jul 4, 2003 08:56 PM
civic dx
Feb 23, 2003 05:48 PM
