ZC Header
'91 CRX Si...
Will a DC Sports stainless header for a d16a6 fit a ZC? I'm just considering a swap and trying to figure out what i have to work with as far as swapping current bolt ons... also, what about intakes? will the AEM short ram work if you swap a ZC?
thanks...
thanks...
yes they will work with the ZC...you should port out the header a little bit because its about 2mm down than the zc, when you get the exhaust manifold gasket you will understand what i mean...
ok, i assumed that it would be similiar atleast... i just didn't know if the ports would match at all, or if the bolts would or what...
anyone know about the intake?
Bump. I'd also like to know which to get, I'm gonna be dropping my stock mani soon and I'd like to know which to buy.
Nevermind, had a hard time searching bc "zc" cant be included in search.
I've done a DOHC ZC and used an 88-91 D16A6 header with no problems. The ZC ports are a tad bit bigger, and I had to portmatch the header to the head, but it wasn't that much material to remove.
