Will Bad Timing Belt Cause Misread on Crank Position Sensor?
Old Apr 19, 2003 | 03:15 PM
gupta_p's Avatar
Default Will Bad Timing Belt Cause Misread on Crank Position Sensor?
I'm getting a code 4 error .. and I remember when I was driving the day the error randomly came up .. the car jerked right before the error came on.
I've not checked my timing belt .. but if it slipped, do you think it would cause my crank position sensor to misread and give me a code 4 error? (btw, since i'm getting this error, i'm rev limited to 3500 rpms)
also .. what are symptoms of a bad distributor? there is a VVERRRYY fine layer of redish brown dust on the parts inside the distributor .. i'm not sure if tha'ts a good thing or not.
THANKS
Old Apr 19, 2003 | 03:45 PM
Chiovnidca's Avatar
Default Re: Will Bad Timing Belt Cause Misread on Crank Position Sensor? (gupta_p)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gupta_p &raquo;</TD></TR><TR><TD CLASS="quote">
The brown dust is bad news. The bearing in there is crapping out. It's probably causing the code also.
Old Apr 19, 2003 | 03:54 PM
gupta_p's Avatar
Default Re: Will Bad Timing Belt Cause Misread on Crank Position Sensor? (TurboD16Chiovnidca)
Yah, I was thinking the brown dust was a bad thing ..
my code 4 .. is that a recoverable thing? Or do you think that sensor is dead?
You think I should replace the bearing? Wil that fix my problems?
Or is my only solution a total distirbutor replacement? (if so .. wtb: distributor for a 92-95 civic cx)
Old Apr 19, 2003 | 04:46 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gupta_p &raquo;</TD></TR><TR><TD CLASS="quote">Yah, I was thinking the brown dust was a bad thing ..
Or is my only solution a total distirbutor replacement? (if so .. wtb: distributor for a 92-95 civic cx)</TD></TR></TABLE>
I usually replace the distributor sub assembly.
Old Apr 19, 2003 | 06:55 PM
gupta_p's Avatar
What would the subassembly of the distributor actually include?
I already replaced my rotor, and distributor cap btw ..
(soory, this is probably a newb question, but I'm definitely a newb still )
Old Apr 19, 2003 | 07:22 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gupta_p &raquo;</TD></TR><TR><TD CLASS="quote">What would the subassembly of the distributor actually include?
No coil or igniter.
Old Apr 19, 2003 | 07:23 PM
gupta_p's Avatar
So.. how much money would I save by going that route? Should I just get an entirely new distributor?
Old Nov 9, 2003 | 08:53 AM
Plan B's Avatar
this happened to me, find a used one and swap over all the electronics from yours that come out with screws.
Old Nov 10, 2003 | 07:04 AM
EE_Chris's Avatar
You can't replace the individual sensors in the disrtibutor, just the whole sub-assembly.
I also see many cases of people cheaping out and buying aftermarket sub-assemblies and having them crap out in short order.....stick with OEM on this item.
Old Nov 12, 2003 | 01:27 PM
Chiovnidca's Avatar
Default Re: Will Bad Timing Belt Cause Misread on Crank Position Sensor? (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">stick with OEM on this item.</TD></TR></TABLE>
Old Nov 25, 2003 | 10:15 PM
rilyn's Avatar
Default Re: Will Bad Timing Belt Cause Misread on Crank Position Sensor? (Chiovnidca)
i have the same problem and i switched ecus and it went away
Derrick_12341
Jul 26, 2018 07:15 AM
pos94accord
Jan 25, 2009 05:29 PM
carlthecrx
Feb 6, 2008 08:34 AM
nayrone
Nov 2, 2004 08:18 AM
nayrone
Nov 1, 2004 07:21 PM
