gasket question
Old Apr 19, 2003 | 02:52 PM
Loveless's Avatar
Default gasket question
ok, so my craftman tools came yestoday, I am going to do my valve adjustment soon and install my neuspeed header.
The problem is that my engine is leaking oil from the valve cover and nothing in the spark plug holes, so I Am assuming I need a valve cover gasket?
ahmotor sell it for 8.45 http://ahmotor.com/product/ahmcat1vcg.html
but kragen sell for 30 bucks?!
the header didn't come with any gasket either. I need an exhaust manifold gasket right? kragen also sell it for 30 bucks. Stock ones fits fine right?
do I have the right gasket names? if so, where should I get them?
Old Apr 19, 2003 | 02:57 PM
mr.beeks's Avatar
Default Re: gasket question (Loveless)
yeap the names are right
but your header gasket ( stock)
do you have any porting on your head, this will steal some HP's
Ps
be carefull not to break any bolts on your valve cover
just hand tight
Old Apr 19, 2003 | 03:16 PM
Loveless's Avatar
Default Re: gasket question (FRANCISCO FLORES)
porting? are you refering to port and polish? no I have not done that.
so I can just install it as is right? (header)
can I use existing gasket?
Old Apr 19, 2003 | 03:19 PM
mr.beeks's Avatar
dont use the old get a new one
and yes you could use stock if no port and polish has been done
you dont want any exhaust leaks right
ps
dont break any valve cover bolts
Old Apr 19, 2003 | 03:28 PM
Loveless's Avatar
yes, I been reading people braking valve cover bolts due to excessive pressure, screw torque wrench (I don't own one yet anyways) I'll just listen to my inner bolt monkey
cyclonedr
Sep 2, 2019 01:09 PM
jackiebenware
Oct 28, 2005 05:31 PM
darkfx
Oct 8, 2005 09:51 AM
Mike1486
Sep 7, 2004 05:26 PM
vteg
Jul 24, 2003 05:14 AM
