Engine Revs on it own
Old Apr 19, 2003 | 01:04 PM
1sloaccord's Avatar
Default Engine Revs on it own
Sup guys, I have a 99 accord V6, and the only thing i got on it is an AEM intake. The problem is that the motor just jumps from 1000-3000 and this is while i'm driving. I put the car in neutreal and it does the same thing. then i disconnected my bettery to reset the ECU and and still does the smae thing. Can anyone help me please. Thanks
Old Apr 19, 2003 | 01:07 PM
honda530's Avatar
sounds like you either have a vacum leak in your egr or your throttle body could be really dirty. Get some TB/carbarator cleaner and clean the tb. If that does fix it then its something with the egr i believe. which is a vacum leak.
Old Apr 19, 2003 | 01:25 PM
1sloaccord's Avatar
Default Re: (honda530)
i checked all the lines and i didn't see anything disconnected, do i have to remove the throttle body?
Old Apr 19, 2003 | 01:52 PM
BB6-00's Avatar
Default Re: Engine Revs on it own (1sloaccord)
sheck ur hoses.. it sound like u have a vacum leak. that is the only thing that makes ur car rev onits own unless u played around with the throotle cable but it doesn't fluctuate taht much like u said.
Old Apr 19, 2003 | 04:17 PM
1sloaccord's Avatar
Default Re: Engine Revs on it own (f23a1)
Thanks for respones, but i checl the lines and their good, anything else?
Old Apr 19, 2003 | 05:45 PM
twkdCD595's Avatar
did you disconnect any valves or anything vaccuum related?
move any lines or reroute them?
pull a sensor plug by accident and not get it clipped back on can do it.
Old Apr 19, 2003 | 05:47 PM
94cd7's Avatar
if it is not a vaccume leak and you are sure of it, you might have a problem with your idle air control valve. my buddy had the same problem. it all started when we cleaned out his fuel injectors
Old Apr 19, 2003 | 06:30 PM
Accord98's Avatar
Default Re: Engine Revs on it own (94cd7)
thats not how u re set the ecu on a 6gen..
you gotta hold down your trip mileage button...for about 7-8 secs..
while the ignition is turned on but not all the way where the engine would start...
hold it there for a couple of secs...and turn the car on..
you'll always have to reset the ecu when installing a aftermarket part. or else the computer wont know how much air its taking in,since it takes in more air then the stock air box.
hope using that re set of ecu helped..
if not bring it to Honda dealer ship.
Old Apr 19, 2003 | 11:09 PM
1sloaccord's Avatar
Default Re: Engine Revs on it own (AccordKid98)
i had the aem there since i i bought my car
Old Apr 20, 2003 | 07:35 AM
Accord98's Avatar
..english plz..
Old Apr 20, 2003 | 04:30 PM
Fastom's Avatar
Check the plug and wiring to the idle air speed control motor. Bad ground or trigger ires will cause engine to have an unstable idle speed
Old Apr 22, 2003 | 07:14 AM
1sloaccord's Avatar
Disconnecting the battery does reset the ECU, what do you guys think bout the TPS sensor.
ghsek99
Mar 1, 2008 11:52 AM
EJ ITO
Oct 30, 2007 11:36 AM
Rex-Si
41
Apr 4, 2007 01:30 PM
R6E6I6D
Apr 13, 2005 12:29 PM
lighteyedhulk
Sep 22, 2004 09:33 AM
