OBD1 Swap Car won't start!!! Code 41
Old Apr 19, 2003 | 12:32 PM
bossman032's Avatar
Default My Baby finally started STD with OBD1 swap Fully Running Pictures etc..
My car does not want to start!!!
The car looks like it wants to start badly but it cant!~~
It’s giving code 41 I know the wiring is right because its only giving code 41
I have not hooked up one Sensor that is the Sensor on the Header I just put the header top peace on.. I didn't put the part where the sensor is the bottom piping..
I ordered a new Distributor.. What else can be the problem?
I have a SIR II Swap cable tranny YS1 on an EF 91 DX!!!
edit: got my new distributor fixed the firing order and ground and the car started up fine!!! thanks to VegasEK for doing my wiring. check out the pictures any questions let me know..
I have a question about people with STD 91 hatch how much these babys weight?
are they much lighter then DX and Si I heard they are but...
thanks for your help!!!!
ronald
Modified by bossman032 at 6:19 AM 4/24/2003
Modified by bossman032 at 6:21 AM 4/24/2003
Old Apr 19, 2003 | 01:07 PM
smokey2.0's Avatar
Default Re: OBD1 Swap Car won't start!!! Code 41 (bossman032)
my car ran poorly with a bad O2 sensor, i think you should wire up that O2 sensor and see if it starts! what ecu, and distributor are you using?
Old Apr 19, 2003 | 10:01 PM
bossman032's Avatar
Default Re: OBD1 Swap Car won't start!!! Code 41 (smokey2.0)
Hello,
I am using a PR3 OBD1 ECU.
Distributor is TD44-U.
will the O2 sensor prevent the car from starting..?
Old Apr 20, 2003 | 01:01 AM
smokey2.0's Avatar
ok, the O2 won't keep the car from starting, but from running right. check to see that your spark plug wires are in the correct place, 1-3-4-2 from lower left to lower right going clockwise! make sure that you're distributor is not 180 degrees off, make sure the key goes in the right spot on the exhaust cam! the other thing i can think off is, to check if you switched the plugs from the map, and tps sensor. if those are switched, the car won't start! good luck! also, check the coil on that distributor!
Old Apr 20, 2003 | 09:24 PM
bossman032's Avatar
Hey smokey2.0,
thanks for your help I will try that.
thanks again.
ronald
Old Apr 21, 2003 | 01:08 AM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">Hey smokey2.0,
thanks again.
ronald</TD></TR></TABLE>
no problem dude, i just hope you get to find and fix the problem so that you can get the car on the road!
Old Apr 23, 2003 | 09:17 PM
bossman032's Avatar
they smokey,
got my car running today it was the firing order or the ground was on the wrong place also got my new dizzy today homeboi did the firing order changed the ground and it started up like wow!!!
Car starts up fine now hell happy.. took a long time to get here but finally here..
My car OBD0 STD Hatch.
B16a SIR II OBD1 Engine.
ECU Harness and Engine Harness Converted to OBD1 :D.
check out the pictures!!!
Old Apr 24, 2003 | 01:23 AM
smokey2.0's Avatar
hey, you did a good job with that harness. if all the wires were gray, i would had thought that you bought that harness. i need to lear how to sorder, so that i could fix some of my wireing in the engine bay! your car looks like mine, i have a blue 88 crx dx! once again great job
Old Apr 25, 2003 | 09:23 AM
bossman032's Avatar
sweet. timing is little off. and need to change piping on the car.. thinking about 2.5 inch piping is that good enough?
Old Apr 25, 2003 | 08:49 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">sweet. timing is little off. and need to change piping on the car.. thinking about 2.5 inch piping is that good enough?
that's what i'm running now, with a dc jdm 4-1 header, and cat!
bossman032's Avatar
hey smokey,
my car won't rev more then 3.5!~~
can you give me some ideas what might be causing it..
I will list the error ecu codes tomorrow..
thanks for all the help!!!
CivicDx88
Engine Management and Tuning
Feb 12, 2012 06:14 PM
88efsedanlx
Dec 10, 2011 05:40 PM
rudyndrew
11
Jan 6, 2011 08:25 PM
91-lsvtecsi
Sep 16, 2007 06:18 PM
