Question for 99 Accords???
Old Apr 19, 2003 | 12:30 PM
2.2L EH2's Avatar
Default Question for 99 Accords???
My friend and I, has recently put on coilovers on to his 99 accord, and the problem is that since we already put on the coilovers its still staying at stock height, Its an inch lower but not as low we wanted it to be. We tried adjusting to make it lower but it wouldnt go as low. We still can fit one fist between the tire and the bottom of the fender.
And also having a problem with rear, I dont know where to start on how to put the coilovers because there is too many bolts, and I dont know which one to take off. I tooken off 3 bolts already but i dont know where to leave off! I took the 2 bolts off, on the top where it holds the whole spring and shocks, and I took another 1 off the bottom off the shocks, this is where i need help on taking the rest of it off.
Old Apr 21, 2003 | 07:37 PM
areyouasian's Avatar
Default Re: Question for 99 Accords??? (Natural Aspirated)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirated &raquo;</TD></TR><TR><TD CLASS="quote">And also having a problem with rear, I dont know where to start on how to put the coilovers because there is too many bolts, and I dont know which one to take off. I tooken off 3 bolts already but i dont know where to leave off! I took the 2 bolts off, on the top where it holds the whole spring and shocks, and I took another 1 off the bottom off the shocks, this is where i need help on taking the rest of it off.
thats the only three bolts you need to take off, have someone step on the rotor to push down the suspension and it should pop out, then you just maneuver(spelling?) it around to clear the control arms to get it out from under neath the fenders.
Old Apr 21, 2003 | 08:29 PM
iam7head's Avatar
Default Re: Question for 99 Accords??? (areyouasian)
6th gen have a tricky rear suspension, the strut/shock/spring is located right behind the rear seats(on my coupe).
take off the 3 bolt on top of the strut will loosen the top part.
it's not hard at all if you know what are you doing. it's all there.
gooood luck
Old Apr 22, 2003 | 05:43 AM
jweller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirated &raquo;</TD></TR><TR><TD CLASS="quote">My friend and I, has recently put on coilovers on to his 99 accord, and the problem is that since we already put on the coilovers its still staying at stock height, Its an inch lower but not as low we wanted it to be. We tried adjusting to make it lower but it wouldnt go as low. We still can fit one fist between the tire and the bottom of the fender.
are you sure you don't the the rears on the front? It's a common mistake. maybe you have the perch flipped?
morseb1
Dec 30, 2009 11:45 AM
type_one1
Oct 15, 2007 06:19 PM
fms1day
Suspension & Brakes
Jun 24, 2005 07:20 AM
fms1day
Jun 23, 2005 02:50 PM
Luchini
Dec 4, 2004 01:02 AM
