compression about a supercharger on a itr (some weird info)
Old Apr 19, 2003 | 08:38 AM
Vampyre's Avatar
Default compression about a supercharger on a itr (some weird info)
ok i just gtot a e-mail saying this
The final compression ratio on a 10.6:1 engine with 8 psi is 16.4:1
which is
really high for cars with pump gas. If you run 6 psi the 10.6:1
compression
the finial compression ratio is 14.9 which is a pretty good limit on
pump
gas. So you might want to run 6psi if you don't change out the head
gasket.
i am tempted to believe you guys over that. so what do you think. i know there are people running 10 psi on the jrsc no probems with stock bottom end and stock head gasket. but **** maybe i am worring to much about this.
Old Apr 19, 2003 | 10:55 AM
Spunkster's Avatar
Default Re: compression about a supercharger on a itr (Vampyre)
No problems here
Old Apr 19, 2003 | 11:01 AM
.RJ's Avatar
.RJ
compression ratio is a static charaticerstic of the motor.
maybe you are confusing compression ratio with cylinder pressure.
ojasia
Jul 13, 2014 08:24 PM
High Reved Racing
Jul 14, 2008 04:37 PM
Renegade
Mar 16, 2006 05:54 PM
nd8ch
Feb 26, 2003 08:10 PM
greyzone
Jun 17, 2001 02:10 PM
