what causes wheel hop????
Old Apr 19, 2003 | 02:15 AM
brega3's Avatar
Default what causes wheel hop????
I was on the tracks the other day and when I started I had some wheel spin and the wheels were hoping like crazy. What causes this?
Old Apr 19, 2003 | 02:16 AM
brega3's Avatar
Default Re: what causes wheel hop???? (brega3)
one other thing why do I still have that little yellow face????
Old Apr 19, 2003 | 09:45 AM
YeuEmMaiMai's Avatar
wheel hop is caused by
1. broken motor mounts
2. broken or worn suspension parts
3. too much power
Old Apr 19, 2003 | 05:49 PM
twkdCD595's Avatar
Default Re: what causes wheel hop???? (YeuEmMaiMai)
stock suspension is too soft and so are the motor mounts... you get wheel hop as everything moves and it fights for traction.
urethane bushings and stiff springs help alot.
BTW you can get wheel hop without a damage mm or something but it will eventually take its toll in short order... cv joints are usually overlooked and take a beating.
Old Apr 19, 2003 | 06:24 PM
sauceman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brega3 &raquo;</TD></TR><TR><TD CLASS="quote">one other thing why do I still have that little yellow face????</TD></TR></TABLE>
It's up to you to choose an avatar for yourself
https://honda-tech.com/zero...40#19
Old Apr 19, 2003 | 06:32 PM
briq4's Avatar
Default Re: what causes wheel hop???? (sauceman)
I used to have a 2001 Type R. and it was brand new, and it had wheel hop like CRAZY and it's sure didn't have too much power... i.e. no torque, but it seemed that the tires were really sticky so rather than just spin, they would get a lot of grip and would overwhelm the suspension. And the R did not have a soft suspension by any means.
Old Apr 21, 2003 | 05:50 PM
brega3's Avatar
I know is not the power. and what should I look for to see what is wrong with the suspension or the engine mount? or should I go to a mechanic and ask him to check it out for me? and thanks for the responses so far
Old Apr 22, 2003 | 05:31 AM
m0t0rhead's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">wheel hop is caused by
3. too much power</TD></TR></TABLE>
4. stock strut rod bushings cause wheelhop
5. stock engine mounts cause wheelhop
6. bad axles
7. stock springs
8. stock shocks
Alot of things add to wheel hop. You will need to eliminate your weaks points. The ones listed above.
Old Apr 22, 2003 | 09:08 AM
KGAccord's Avatar
Default Re: what causes wheel hop???? (Escobar)
low profile tires
negative camber
fwd
Old Apr 22, 2003 | 02:13 PM
brega3's Avatar
WOW.... man do I have to check all those things to see what is causing this? or should I be carefull not to chirp tire anymore....
Old Apr 22, 2003 | 02:41 PM
RotaryBzzz's Avatar
clutch technique / flywheel action
Old Apr 22, 2003 | 08:07 PM
iam7head's Avatar
Default Re: what causes wheel hop???? (RotaryBzzz)
my f-up shocks on my 13 years old car
civicsaremean
18
Jul 23, 2007 11:17 AM
allmotor99lude
Nov 23, 2005 09:27 PM
elitesi8
Oct 9, 2005 06:42 AM
project-boosteD
May 3, 2004 03:00 PM
msmithgsr2131
Feb 16, 2004 08:59 AM
