B18a won't start HELP
Old Apr 19, 2003 | 01:25 AM
si foo's Avatar
Default B18a won't start HELP
Hey guys my car died off the highway. It cranks but won't start. There's no spark even after changing the distributor. The ECU read a 4 and 3 what could it be? Oh yeah it's a LS engine with non OBD....thanks for any help
Old Apr 19, 2003 | 11:38 AM
si foo's Avatar
Default Re: B18a won't start HELP (si foo)
anyone?????
Old Apr 21, 2003 | 05:48 AM
JimBlake's Avatar
3 = MAP; manifold pressure sensor
4 = CKP; crank position sensor
Those are for a '95, do the earlier ones use the same codes??
They seem kind of unrelated to each other... Maybe check how good the wiring connections are at the ECU??
Old Apr 21, 2003 | 09:20 AM
NY-Trizz's Avatar
You said you had no spark?? might be a bad igniter, or a your coil. Pop the cap off and check your connetions, make sure nothing is touching each other.
kotehzz
May 6, 2011 06:27 PM
sohc90rex
16
Dec 21, 2005 09:20 PM
.one lane
Oct 17, 2005 07:40 PM
iphatcrxi
Oct 19, 2004 04:13 PM
tdc
Jul 19, 2003 12:44 AM
