I might be screwed.......please help
what up, ok i got a 93 LS.....bout 75k miles on it........went into best buy came out and the car cranked right up, my motot seatbelts wouldnt come back though as if the door was left open so i turned off my car for about 15 sec. went to turn it back on and nothing..........it is turning over just like it wants to start but its not starting........again i say it is turning over just fine its not slow or anything sounds just like it should............i changed spark plugs.....i have my back seats out and i cant hear my fule pump kick in....i also am gettin no fire from my spark plug wires when i pulled one out and grounded it to a screw, and valve cover i felt and got nothing..........................anyone have any advice at alll??? thanks
Maybe your coil... also I'm not sure what fuses you have on the car but it couldn't hurt to go through them too especially with your seat belt problems...
yeah i checked all the fuses they are all fine and this is the first time my seat belts have ever done that..........and my coil is an internal coil so i have to buy an all new distributor right?? also what about my fuel pump i am not hearing it kick in?
well man the best thing i would say is that your coil went out. if it goes car will crank fine but it wont turn over. i had the same problem , cost me $256 at honda. dont do that stupid mistake to go there. might as well get a msd blaster coil system it will be cheaper and give you a little added performance.
what i had was a 92 acura integra gs:
aem cold air intake, dc header, thermal cat back , random technology high flow cat, msd blaster 2 coil, cap, accel thundersport wires, bosch +4 plugs, akimoto dress up
what i got now: 99 gs-r bone stock
i want some boost!!!!
maybe i'm way off on this... but is ur battery ok? cuz if ur starter is good, perhaps it still doesnt have enough power to crank the motor up.? wait that would still not explain why the motor started up at first and the seat belt didnt werk... hmm... well free bump for ya... maybe someone else knows.
im just not understanding why im not gettin any fire from my plug wires.........and at the same time im hearing nothing from my fuel pump and the battery is good everything works....windows radio sunroof the only thing is that the seat belts wont come back.....im thinking electrical but i dont know im so confused bout to have it towed to be put on a diagnostic computer...
I'm pretty sure it's the coil now you mention you have no spark also. Samething happen to my gf's former car, a 93 Accord. The coil went out, the car would crank but won't start and had no sprak from the wires. Just get a aftermarket coil, it's like $50.
Do you have a fuel pressure gauge???
If you doubt the pump is working check it with the gauge and that will tell you if the pump is working...
Also you can pull the carpet and use a Volt meter to test if the pump is getting voltage... or test at the fuse panel behind the kick panel on the drive side.
If you think you aren't getting spark and the screw didn't work you can also pick up an inline spark checker for like 5-10 bucks at most automotive part and tool stores.... also you might want to check the ecu if you have the ability to do that... Maybe something burned up in the ecu?
The ecu is located under the carpet on the passenger side firewall... It also has a error code light that you can at least have the ecu give you the codes and then look them up if you have any ecu problems.
But I would start with the easy stuff first... try testing the coil with a volt meter and the fuel pressure guage and go from there.
its a common problem with most
g2i
internal coil and ignition module tends to fail
get an msd coil ($45-60) wich is better
the cap around ($45)
then you have the option to buy the ignition box (6a $180) (6AL $220)
ignition module ($80)
or if you want to buy a new distributor
http://www.hondadistributors.net
but most teggys dont make any hissing sound from fuel pump
g2i
jpnolan
11
Jul 22, 2009 08:31 PM
markH22eg6
12
Apr 12, 2008 04:02 PM
2007coupeEX
Honda Civic (2006 - 2015)
Oct 18, 2007 04:22 AM
